It this part the lower control arm?
Old Oct 4, 2007 | 12:43 PM
Gilley's Avatar
I was under the car the other day and noticed this pivot point for the lower suspension on the left front of the car. The arm was not centered on the splines.
I used a rubber hammer to get it back in place to look like the photo below, but I don't think it's a permanent fix.
From the front suspension drawing in the service manual, it appears that it is the lower control arm. I just want to verify it before ordering a new one.
No. 13 appears to be the part I need and is called the transverse link in the service manual.
www.everythingg35. com lists it as the lower control arm, No. 11. http://www.trademotion.com/partlocat...11&catalogid=1
Old Oct 4, 2007 | 12:54 PM
superchargedg's Avatar
Yep that is it and you have bushing failure,you might be able to just get the bushing,s and have a shop press them in the control arm.Also an alignment should be done as well.
Old Oct 4, 2007 | 02:21 PM
Gilley's Avatar
Thanks. It should be covered under warranty, but my car is low and has a body kit so I'm afraid that the dealer would cause more damage than buying a new arm and installing it my self. It's $163.69 online.
Old Oct 12, 2007 | 12:49 PM
XtremeCoupe's Avatar
Over the last week or so, I have been hearing excessive grinding/squeaking coming from the driver's front suspension area, so today I jacked it up and decided to take a look and my LCA has done the EXACT same thing. I'm lowered on 350Z H-Techs so I'm wondering if that is part of the problem. Anyway, where did you find a replacement LCA? I need to order one as well. Thanks!
Old Oct 12, 2007 | 12:53 PM
Jeff92se's Avatar
Red Card Crew
Dang, time for someone to offer poly bushing inserts. I wonder if Energy or someone has them?
Old Oct 12, 2007 | 01:35 PM
Gilley's Avatar
I just got ine delivered today from www.infinitipartsusa.com, which is part of everythingg35.com. They have $5 shipping for October, which saves another $11.
Old Oct 12, 2007 | 01:46 PM
Oh nice! Good luck with the install, thanks for the info!
Old Oct 17, 2007 | 04:30 PM
WILLIE BEANS's Avatar
any info on polyurethane bushings .. for control arms or sterring racks .. for g35 coupes or sedan ..??
Old Nov 21, 2007 | 07:38 AM
waijai's Avatar
i.love.gold
While my car was on the lift, I saw mine was like this as well. They people at the dyno strapped the front of my car to the lower control arm, so it pulled the arm off center.
Old Nov 21, 2007 | 10:46 AM
Gilley's Avatar
Update: I got mine from infinitipartsusa.com and installed it in less than an hour with hand tools. It's all good now.
Old Nov 21, 2007 | 12:27 PM
waijai's Avatar
i.love.gold
Did you get the whole arm or just the bushing? Nismo offers a replacement bushing I might do.
Old Nov 21, 2007 | 04:39 PM
Gilley's Avatar
I got the whole arm. I don't think I could have replaced my bushings.
I wonder if my lower control arm was damaged when they strapped it down on the dyno.
Old Nov 21, 2007 | 04:51 PM
Jeff92se's Avatar
Red Card Crew
Did you install it loose, put the wheel back on and put it on a ramp before doing the final torque down?
Old Nov 22, 2007 | 11:24 AM
myG35ZX's Avatar
How are your compression rods?
Old Nov 22, 2007 | 01:13 PM
Gilley's Avatar
No. I have no way to do that.
