Brake, SLIP, VDC off Lights up. help.
Old Oct 10, 2007 | 06:35 PM
mubay's Avatar
BRAKE, SLIP, VDC OFF suddenly lights up after i start the engine. I check my hand brake [ it's off already], i try to turn on the VDC but VDC off still lights up.
Anyone know what happens to my car? I'm sorry i don't have time to do search becoz i'm just panic right now. i'll try to search after i post this.
thanks.
Old Oct 10, 2007 | 06:55 PM
mubay's Avatar
i just called dealership, he told me that it might caused by low brake fluid level. it's sound logic because yesterday was 80'F and today is 44' F. btw, Is there any like warning lights or something when we need to replace the brakes [pads and rotors]?
Old Oct 10, 2007 | 07:04 PM
mubay's Avatar
Originally Posted by ZXERT
https://g35driver.com/forums/showthread.php?t=142710
Heres a reference thread.
You can stop panicking now, this is a common issue. VERY COMMON.
thanks for the info. his problem a bit different with mine. as those light still lights up even though i stop the car. i checked my car just now, brake light is gone. but slip and vdc off still light up.
Old Oct 10, 2007 | 07:26 PM
chuckd05's Avatar
dude i just went through this problem, and searched around like crazy ... a lot of people said check brake fluid levels, mine were fine, there were several things i found that lead to easy fixes.... MINE on the other hand was a whole different monster.. turned out my vdc unit was whacked, along with an abs sensor, and wheel something sensor.. took the place like 2 weeks to find it out... told me it could of been caused by my cracked rim being out of round, or wrong tire combos...
thank god i knew the guy because he said they put over 20 hours into the car to troubleshoot it...
does ur intake sound louder than normal too when you gas it ? the car doesnt run quite right when all the lights are on...
check brake fluid levels tho, a lot of people said that was there problem..
or if not start checkin wheel sensors , vdc units, etc
Old Oct 11, 2007 | 01:05 PM
mubay's Avatar
last night those warning were gone but they were lights up again this morning. i noticed that those warning started lights up after i released the parking/hand brake. any solution? Infiniti dealer is like 2hours drive from my house so i'll take my car to nissan dealer today. let's see what they say.
Old Nov 18, 2007 | 10:33 AM
mubay's Avatar
yeap! those lights gone after i added brake fluid.
Hasanbaloch
Feb 29, 2024 08:45 PM
Mry
Mar 3, 2023 01:03 AM
SiMpLyMoDiFiEd
The FX-Spot
Dec 2, 2021 04:35 PM
Wayne9011
Aug 17, 2015 01:24 AM
Wayne9011
Jul 27, 2015 11:25 AM
