hit a curb.. whats likely damaged?
Old Oct 31, 2007 | 02:21 AM
Andrew37's Avatar
hit a curb.. whats likely damaged? *pics*
Lost it around a corner... drivers side front and rear got up on the curb (square curb, quite large (yes im a dumbass))...
my alignment is totally whacked now (obviously) car veers HARD left on its own... so far i know this:
- both drivers side rims are toast (aftermarket here i come)
- front bumper is totally toast (kuruma here i come)
- drivers side wheel well is totally ripped out (sitting in my trunk)
- plastic guard that protects under side of car is holding on by 1 clip
- drivers side fender is bent
what can i expect to replace as far as steering components/stuff i cant see? I havent had a chance to get the car up with the wheel off yet to get a real good look.
*pics*
Old Oct 31, 2007 | 05:16 AM
alphamatt's Avatar
ouchy area, have you had it looked at by a skilled mechanic? could have harmed the frame and possibly engine pins, hope everything works out well for your g, accidents happen.
Old Oct 31, 2007 | 07:58 AM
chilibowl's Avatar
You shoulda known these cars are tail happy, you cant be mashing it around a corner homie... I say you take it to an independent shop ( DO NOT TAKE YOUR CAR TO INFINITI) and have it inspected. You could possibly have a cracked control arm causing your hard pull to the left.
http://riversideinfiniti.com/j/i/224...LineParts.html
Old Oct 31, 2007 | 08:39 AM
jclit's Avatar
you might want to invest in a driving course class.
Old Oct 31, 2007 | 08:41 AM
RBull's Avatar
Rated M
I don't find they are tail happy (oversteer) at all. They actually push (understeer) more than most unless you're comparing to FWD.
Old Oct 31, 2007 | 09:15 AM
App6MT's Avatar
Littering and...
I jumped a curb in mine and it screwed it up pretty badly. It will be different for every car. Just take it to a very skilled mechanic that you trust to have it looked at.
Old Oct 31, 2007 | 09:38 AM
fortified's Avatar
A good pothole or curb hitting adventure will definitely change the alignment.
Tie rods are like toothpicks. But that hard definitely deserves a good inspection.
Old Oct 31, 2007 | 10:07 AM
Hi-TechG35's Avatar
Inner an outter tie rods, axel, bent or dented oil pan, cats, O2 sensors, wheels.
Old Oct 31, 2007 | 11:24 AM
VCG35's Avatar
Man that sucks dude gl with the repairs.
Old Oct 31, 2007 | 11:27 AM
chilibowl's Avatar
Ummm...in 2nd gear at WOT, this car will easily, easily kick its a.ss out around a corner, especially on worn tires.
Old Oct 31, 2007 | 11:49 AM
Klubbheads's Avatar
similar crap happened to me back in the stupid days, but i was lucky. Mine was just alignment problem. I felt dumb when it happened though.
Old Oct 31, 2007 | 11:53 AM
DRAGMODE's Avatar
Been there, done that.... hahahaha Live and learn. I'm thinking about going to the skip barber driving school!
Old Oct 31, 2007 | 11:55 AM
RBull's Avatar
Rated M
Yes and so will a lot of cars driven like that. That's not indicative in itself of being "tail happy".
The car has a nature of understeer.
Old Oct 31, 2007 | 11:59 AM
Klubbheads's Avatar
^ i agree. The most hated part by me when it was stock.
Old Oct 31, 2007 | 12:03 PM
RBull's Avatar
Rated M
I've got mine lowered on Z springs, dspecs and stillens f+r. It takes work to make it oversteer.
