Sway bars installed but have questions...
Originally Posted by Klubbheads
Because majority of infiniti's costumers are going to be average daily drivers who can care less if the car under steers or not. It is a common misconception that under steering is safer than over steering.
When oversteering, getting off the gas or trying to correct might get you into way too much trouble. ie.. 180, 360 etccc. especially in the rain
Wouldn't that mean that the nonsport suspension would be prone to oversteer then? I've driven both in stock form the sport suspension definetly is more neutral.
Originally Posted by Jeff92se
For the vast majority of drivers, understeer is much easier to bail out of. When understeering, you only have to get off the gas to control it.
The thing is med front is diff than med rear. If I remember, the stiffness ratings are diff from frt/back. So putting it med front makes is let's say 25% stiffer. But a med rear might make it 35% stiffer than stock. Or vice versa(note I just made up the % for conversations sake)
That is a good question, i guess im gonna stiffen up the front also and see what kind of difference it makes. But I KNOW that on my car when i had it on medium/medium, the front felt heavy and tended to push it out.
Stiffness settings for the front/rear sways:
Front - Rate Increase over stock +9%,+32%,+63%
Rear - Increase over stock +54%,+92%,+146%
So right now im 32% stiffer in the front and 146% stiffer in the back.
You may have reached the point where your rear is so stiff its no longer contacting the ground efficiently. Try soft front and med rear if you have the chance, and see if your opinion is still the same.
![Big Grin](https://g35driver.com/forums/images/smilies/biggrin.gif)
Originally Posted by seung012
Wow. okay... lot of info. I have g35 tein h-tech springs. So I should go ahead and put the rear stiff? I use to drift my car at events alot. I'm not sure what settings would benefit me.
#30
I just switched the settings from stiff/med to stiff/stiff. Went to a local test track and tore this baby appart. One thing i noticed was the front goes into a turn more direct now. There is the usual oversteer at the limit, but the front is much more direct now. I think this is the best setting for me and the setup that i have. A bit of oversteer and a very direct turn in.
