G37 Brakes on a G35?
Old Nov 15, 2007 | 07:02 PM
The_Scooch's Avatar
So I'm wondering if the G37 sport brakes (4 pot front, 2 pot rear) would fit the G35. The rotors on the G37 are slightly bigger too.
If so, would the cost be comparable to aftermarket to do the switch?
Does anyone have any insight on this?
Old Nov 15, 2007 | 07:22 PM
Bigd2k6's Avatar
i don't know but that'd be sweet. when i saw those brakes on the showroom model, i knew we should've waiting a couple of years for the g37. the g35 looks so playskool now. but like i read on this forum: that's the whole reason they came out with next year's model-to make it better.
Old Nov 15, 2007 | 07:27 PM
NJlakeshoreG's Avatar
the brakes are pretty big...14 inch in front and 13.8inch in back...thats some big factory brakes on a car thats not a turbo porsche...lol..
Old Nov 15, 2007 | 07:37 PM
fairwaywiz's Avatar
isnt that the whole reason for coming out with a new model... to make it better???
Old Nov 15, 2007 | 10:58 PM
G35fromPA's Avatar
This has been asked already. Do a search.
Bottom line is that they wouldn't likely fit, and I'm not sure you'd get any better results than going with an aftermarket BBK that's been tested for the G35, like Stoptech's.
Old Nov 16, 2007 | 01:14 AM
Triple8Sol's Avatar
As with all brake upgrades, it will fit. You'll need to machine some custom brackets and find the appropriate hardware, but it's always doable. Direct swap? Dream on...
Old Nov 16, 2007 | 01:42 AM
solopresident's Avatar
teamsolo.net im-integline
how much would you be willing to pay for it?
Old Nov 16, 2007 | 06:20 AM
yea, buy solos..he got some 40 piston calipers...lol
Old Nov 16, 2007 | 11:23 AM
The_Scooch's Avatar
My question was not so I could go buy the set-up and do it, unless it was much more economical than an aftermarket BBK and directly bolted on. It would be a no brainer then. I was more curious than anything.
I did a search. Maybe I'm not that good at pinpointing the exact phrase that someone else said to produce less than 50+ matches on "g37 brakes...".
But as somone else here agreed, a direct bolt on situation would be pretty cool. If the $$$ was the same as an aftermarket kit, I would most likely go with aftermarket to get the additional benefits of pad and rotor choices and let's not forget about how nice red calipers look. I mean, if you're going to spend the money, you should get the red paint too.
Old Nov 16, 2007 | 12:52 PM
G35fromPA's Avatar
Took me about 8 seconds:
https://g35driver.com/forums/showthr...ght=g37+brakes
Well, as has been discussed many times here, the real benefit of a BBK is supposed to be better thermal handling capacity to avoid brake fade. If that's your goal, then a BBK makes sense. If you're looking for shorter stopping distances, then your best bet is stickier tires. If it's for looks, then that's a different story. You may want to read some of the articles on brake systems from Stoptech, like this one:
http://www.stoptech.com/tech_info/wp...formance.shtml
Old Nov 16, 2007 | 01:12 PM
The_Scooch's Avatar
Good article. Thanks.
I've considered StopTech for a while now. It's quite an investment.
Old Nov 16, 2007 | 03:12 PM
G35fromPA's Avatar
It is, but when you consider how much R&D they put into their product to ensure that it has the right brake bias, etc., it's worth it, especially when you compare the cost of trying to buy a set of G37 brakes from the dealer and then add the cost of modding them to fit a G35. You really have to think about what the objective is for a BBK...
Old Nov 16, 2007 | 03:33 PM
Jason@Riverside's Avatar
the G37 Calipers wont bolt up to G35 or 350Z...
the spacing between the caliper bolts on the CV36 and V35/Z33 spindles is totally different... not to mention the offset on the rotor...
the G37 Calipers look great, are reasonably priced... but wont bolt up without alot of modification which would make it not even worth it...
Old Nov 16, 2007 | 05:59 PM
hey jason..do you happen to know who makes the calipers this go around??? we all know it was brembo last time...is it brembo again???
Old Nov 16, 2007 | 06:02 PM
no idea...
doesnt have any imprinting on it...
i have a g37 caliper new in box next to my desk...
ill take some photos
