Installing Tein springs myself...
Old Dec 9, 2007 | 05:05 PM
Gon21s's Avatar
I have an 03 sedan and I plan on installing them with a buddy of mine that lowered his Acura TL with no problems. Is there anyone that has done this before to their G sedan that has had any complications that I may need to watch out for???
Old Dec 9, 2007 | 05:12 PM
rookie's Avatar
Spring compressor would be a good idea.
Old Dec 9, 2007 | 05:15 PM
VQ Hotness's Avatar
ITs pretty easy, The only thing that takes time is switching the springs on the front shocks. The rear is cake.
Old Dec 9, 2007 | 05:16 PM
06g35meister's Avatar
getting the stockers out is the worst, my buddies 05 was rediculous, as ^^ said spring compressors are a must, and youll need 2 pry bars and a buddy. make sure you hit it to where there is and outlet, if you get it jammed in there... oh boy... 3+ hours (i would know) otherwise, its pretty basic.
Old Dec 9, 2007 | 05:34 PM
Gon21s's Avatar
I have a spring compressor. I was just making sure there wasn't anything out of the ordinary with our cars... I s that your FX Rookie?
Old Dec 9, 2007 | 05:39 PM
rookie's Avatar
Big ol' breaker bar is very helpful on virgin hardware, have the entire front end up should help take the load off the suspension vs doing one side at a time.
Yes sir on the FX.
Old Dec 9, 2007 | 05:56 PM
Gon21s's Avatar
That is the sickest FX I've ever seen. Breaker bar? same as pry bar?
Old Dec 9, 2007 | 06:03 PM
johnsonhuang's Avatar
who needs a spring compressor when u got your stock jack?
Old Dec 9, 2007 | 06:04 PM
people who want the insurance of doing the job right?
jk jk man
Old Dec 9, 2007 | 06:10 PM
rookie's Avatar
Breaker bar
The longer the bar the mo torque you have to apply. 18" is a pretty good size, putting a pipe onto a socket wrench works too.
Old Dec 9, 2007 | 08:54 PM
crislbcG35's Avatar
Originally Posted by rookie
... putting a pipe onto a socket wrench works too.
+1
Old Dec 10, 2007 | 10:19 AM
Gilley's Avatar
A spring compressor does make it nice. Some people don't use one.
Here is a how to. https://g35driver.com/forums/brakes-suspension-diy/104137-long-overdue-fix-my-diy-suspension-how.html
Old Dec 10, 2007 | 02:01 PM
ttrank's Avatar
Grocery getter
A compressor helps a lot. I also found that an offset wrench is nice to have if you don't have an impact to take off the top nut.
snic09
Nov 8, 2017 01:46 PM
StreetStandard
Suspension-Vendor
Jan 18, 2016 03:36 PM
reavensf
Sep 17, 2015 11:30 PM
andresito7
Aug 1, 2015 04:53 AM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
