View Poll Results: Which to do
Keep the H-techs and spend the extra $200 on other mods
38
71.70%
Swap to S-techs and dont bother with the FRONT camber kit
28.30%
Voters: 53. You may not vote on this poll
Kicking myself again..
Old Dec 21, 2007 | 11:48 AM
patman530's Avatar
^^ you should've at least gotten the Z H-techs, the spring rates are higher and closer to the OEM sports suspension springs. when I got my Z H-techs, the ride hardly changed at all
Old Dec 21, 2007 | 12:32 PM
bigc's Avatar
Wings Nation
Originally Posted by DRG35R
rotating? do you have non-directional tires or do you mean having tires taken off rims and switched side to side? too much work, cost and chance of damage to rims to be worth it. just get a camber kit and be done with it.
i think you may have confused more people with your clarification, but point taken on running the risk of damaging your wheels in the process.
for those interested in having your tires demounted, moved to the other side of the car, remounted and reinstalled, it should cost you less than 100 bucks. a shop in socal quoted me 60 and per some other folks on the forum say it can be done for as little as $20-40.
in any event, i think he's better off getting the front camber arms and doing it the right way
Old Dec 21, 2007 | 01:09 PM
Qclass's Avatar
what about the toe ? can u adjust it without adding camber kit ?
Originally Posted by ISMSOLUTIONS
Yea...the caster is really important to adjust..and if you have a miracle way of adjusting it without a camber kit...be my guest!
So...get the camber kit......
Rick
Old Dec 21, 2007 | 09:11 PM
G37Rider92649's Avatar
TANABE SPRINGS, SPC CAMBER KITS ALL DAAAA WAAAAAAAAAAY. I been through 3 different springs, H&R, TEIN, NOW TANABE and im sticking with it. But besides that, Option 1 all the way, i use to have H-Techs, wasnt low enough for me, S-Techs too low.
Old Dec 21, 2007 | 10:10 PM
O HELLA OEM's Avatar
1. Ftw
Old Dec 21, 2007 | 10:21 PM
lniivedl's Avatar
Well I just decided to stick with the 350z H-techs..did the springmount mod today after a few problems, and I'm THROUGH with suspension for awhile..
btw.. since I jacked up the car will it take a couple days for the springs to settle back to where they were? I cut 1/2" on the springmount but apparently it dropped only about 1/4"
I was expecting to see immediate results so I can be satisfied with the work, but I'll be pretty disappointed if it stays the same :/
Anyways thanks everyone for all the votes and advice
Old Dec 21, 2007 | 10:22 PM
ISMSOLUTIONS's Avatar
yea...all you can do is set the toe and let it go on these cars, unless you put on kits.
Rick
Old Dec 21, 2007 | 11:13 PM
bigc's Avatar
Wings Nation
they'll settle more over the next few days
Old Dec 22, 2007 | 01:01 AM
Ayankees2772's Avatar
Originally Posted by Sportcoupe35
I thought the tires were directional tires so can't swap them???
Anyways, I'm riding on 350z Tein H Techs and my rears are in spec but my fronts are ever so slightly cambered....I just live without the camber kit.
If you have the G35 H Techs though, I heard they give you an extra .3" drop over the 350z H Techs....camber kit could be a necessity.
Is this true? I thought the 350z H-techs had a lower drop then the G35 h-techs?
Old Dec 22, 2007 | 07:11 PM
SFLG35's Avatar
FGC President
i have a set of kinetix front a arms if you are interested. havent decided if i want to keep them and put them back on or not. let me know
Old Dec 23, 2007 | 11:06 AM
shaneotool's Avatar
You are correct - the other guy is mistaken.
Old Dec 25, 2007 | 03:59 AM
tjlazer's Avatar
If you want better spring rates I would get some RS*R Down 350Z springs instead of the Tein S Techs...
aktif8
2nd Gen (V36) Sedan
30
Aug 5, 2017 11:47 PM
Danielek
Oct 7, 2015 09:59 AM
edwinisdumb15
SOCAL Meetings & Events
Aug 17, 2015 03:21 PM
