View Poll Results: Which to do
Keep the H-techs and spend the extra $200 on other mods
38
71.70%
Swap to S-techs and dont bother with the FRONT camber kit
28.30%
Voters: 53. You may not vote on this poll
Kicking myself again..
Old Dec 20, 2007 | 11:16 PM
lniivedl's Avatar
So a month or so ago I had TEIN H-techs installed along with the SPC rear camber kit..
and now I'm realizing I should've gone with the S-techs.. -__-
My main concern is the necessity of the FRONT camber kit. I know ideally I should get it, but how necessary is it for normal driving?
SO
1) Keep the H-techs and spend the extra $200 on other mods
2) Swap to S-techs and dont bother with the FRONT camber kit
Sorry mods if this should be in the suspension forum, but I just thought it was more of a general opinions matter more than technical. Also sorry this subject has been beaten to death.
Old Dec 21, 2007 | 12:07 AM
redlude97's Avatar
Even with H-techs, camber arms would be ideal, I am on h-techs and I had a great alighment done, and I still get feathering on the front tires. The S-techs IMO definetly need camber arms front and rear
Old Dec 21, 2007 | 01:08 AM
bigc's Avatar
Wings Nation
go with option 1 - and by other mods, i mean you should get the front camber arms. they are a necessity if you don't want to replace your tires early / have them swapped side to side every few months.
Old Dec 21, 2007 | 01:23 AM
doctorG's Avatar
the G out of the factory needs a camber kit
Old Dec 21, 2007 | 02:55 AM
lniivedl's Avatar
do u mean the FRONts or the REARs?
Old Dec 21, 2007 | 08:14 AM
chilibowl's Avatar
If your tires are feathering, you have toe issues homie. Im on my 350Z S-Techs, and my front is pretty dumped. I only have a 1 finger gap. I got mine aligned, and only my camber is off. Everything else, is back in spec. Ill be rotating my fronts every 6 months or so, since I dont drive much.
Old Dec 21, 2007 | 09:25 AM
DRG35R's Avatar
20 Year Member
G35 Coupe "Sport Package"
you mean take tires off the rims and switch to other side. most tires for G are directional and the wheels can not be "swapped" side to side. just posted for clarity in case someone thought you could do this.
Old Dec 21, 2007 | 09:28 AM
DRG35R's Avatar
20 Year Member
rotating? do you have non-directional tires or do you mean having tires taken off rims and switched side to side? too much work, cost and chance of damage to rims to be worth it. just get a camber kit and be done with it.
Old Dec 21, 2007 | 10:04 AM
GR8TG35's Avatar
I think he means dismounting the tires and swapping sides.......Even the Infiniti dealers do that if you want as part of their services......
Old Dec 21, 2007 | 10:07 AM
Sportcoupe35's Avatar
I thought the tires were directional tires so can't swap them???
Anyways, I'm riding on 350z Tein H Techs and my rears are in spec but my fronts are ever so slightly cambered....I just live without the camber kit.
If you have the G35 H Techs though, I heard they give you an extra .3" drop over the 350z H Techs....camber kit could be a necessity.
Old Dec 21, 2007 | 10:14 AM
dofu's Avatar
20 Year Member
I'd save up and get a full suspension
You can't rotate directional tires unless you remount them...
Say your driver's side front tire wears on the inside but the outside is fine, if you take the tire off, turn it around, remount the tire, then mount the wheel on the other side, you just extended your tire life.
Old Dec 21, 2007 | 11:16 AM
ISMSOLUTIONS's Avatar
Get the front camber kits and either Tein basics or flex coilovers...you'll end up getting them anyway...this way you wont have to make another thread like this one.
Rick
Old Dec 21, 2007 | 11:24 AM
Qclass's Avatar
a slight camber is not that big of a deal, just get the toe and caster spot on.
Old Dec 21, 2007 | 11:30 AM
Yea...the caster is really important to adjust..and if you have a miracle way of adjusting it without a camber kit...be my guest!
So...get the camber kit......
Rick
Old Dec 21, 2007 | 11:45 AM
gnasrawi's Avatar
I got G35 H-Techs on SPC Front and Rear camber kit. Alignment is great but very dissapointed with the ride quality of the Tein. I should have gotten the Eibachs.
