Brake Issues
Old Dec 28, 2007 | 12:35 PM
pinky1121's Avatar
Brake Issues
I can’t even begin to tell you guys how frustrated i am right now!!! Maybe you guys can give me some recommendations but here it goes, 6 months ago i brought my car to a shop not dealer to have my brakes check, the told me i need new brakes and new front rotor on my 03 sedan, so i agree to it and have him replace it, he got me original brake pads to go along with a OEM Brembo rotors, after that my car started making noise when ever i brake, few months later i finally couldn’t stand it anymore, so i go on the forum and post a thread and got some feed back from some of you, they told me to go with Hawks brake pads because they are low dust and low noise, and some one was nice enough to give me instructions on how to replace them DIY, so i follow the steps and successfully got them done myself, all 4 of them... a month later yesterday, my car started making noise again, spoke to a different mechanic and he told me its best to get everything original from Nissan including brake pads and rotors but it is going to cost $$$ again, so here i am 6 months into the new rotors 2 sets of brake pads and $500+ out of my pocket and count less hours of working on my car and nothing was accomplish, still have the same problems... now do you guys think it could be the rotors that the first mechanic put in? Should I get new front rotors? if so what are the best brands and model that will work with Hawks brake pads? Thanks for reading my frustration.....
Old Dec 28, 2007 | 01:02 PM
chrisg_101's Avatar
I got a some R1 concepts rotors that were not very expensive. Haven't had a chance to put them on yet but I read they were good from one of the threads on here
Old Dec 28, 2007 | 02:41 PM
Voodoo's Avatar
CCT-we call down the rain
Sometimes dirt can get between the pads and rotor and cause noise. Try cleaning with brake cleaner, might just be dirt or very small stone.
Old Dec 28, 2007 | 03:05 PM
pinky1121's Avatar
So are you telling me to take the brake pads off and check if there is something stuck in between or just try to use a dust can and dust it? I am despreate here i dont know what else to do.... thanks
Old Dec 28, 2007 | 03:38 PM
dunglan7's Avatar
^You don't have to take the brake pads off. Just spray it in between the pads and rotors with brake cleaner. You'll be amazed at how much dirt gets stuck in between there. Also did you put the caliper shims on right. The caliper shims on that brake shims. There is a part on the shims that hook up to your pads. I forgot to do that so that was one of the reasons why my car was making noise. But some people have problems with Hawk pads squealing also. My Project MU squeal like crazy but with the Hawks they do it from time to time.
Old Dec 28, 2007 | 03:48 PM
Deezflip's Avatar
did you have Hawks HP Plus or HPS? I think one or the other has known to be squeeky.
Sometimes it's all about the material compound of the pads that makes a difference. Our cars are just picky about certain parts.
As for me, I went for the tirerack brand ceramic pads. So far so good, much quieter than ever before.
Old Dec 28, 2007 | 04:12 PM
pinky1121's Avatar
The the brake spray are like the brake cleaners just spray on to the surface of the rotor? and the brake pad shims are you talking these? see attach picture!! I didnt put these on, are they suppose to be place back onto the brake pads?
Old Dec 28, 2007 | 04:15 PM
pinky1121's Avatar
I have the Hawks HPS, i had them on for one month and they were fine until last night they started making noise again, could resurficing the rotor makes a difference?
Old Dec 28, 2007 | 04:21 PM
ScubaSteve312's Avatar
hmm i have the same prob with my OEM rotors (which replaced along with the pads 4 months ago), they squeak allll the time. makes my car sound like a p.o.s
Old Dec 28, 2007 | 04:23 PM
Deezflip's Avatar
Yup those are shims...they'll help...
check this out, perfect thread for your situation...
https://g35driver.com/forums/brakes-suspension/107948-hawk-hps-squeal-solution.html
Old Dec 28, 2007 | 04:57 PM
pinky1121's Avatar
https://g35driver.com/forums/showthread.php?t=107948
So i should put these shim back? also should be apply anti squeal compound on both side of the shim? and type of anti squeal compound works the best?
Old Dec 28, 2007 | 11:42 PM
Gilley's Avatar
The shims are supposed to go back onto the new pads. Use some antisqueak compound. I've been using some CRC anti squeal spray (it's like glue) with good success.
Old Feb 8, 2008 | 01:55 PM
funraiser's Avatar
2004 G35 Coupe Pad and Rotor Problem
I bought my car with 24k miles last year. I just took it in for service only to find out that it needed new pads and rotors on the front. Upon checking the serrvice record, I found that they pads and rotors had been replaced/resurfaced at 22k miles. This sems like excessive wear to me. I also found out that Infiniti US felt the same way and issued a Brake Service Initiative good for 36k miles (IUS states that the pads in the 2004 were found to be too soft).
I don't know if the replacement/resurfacing work was done under the BSI. I was never informed by the selling (Infiniti) dealer about the BSI, so didn't know to have it checked prior to expiration.
My questions are:
Has anyone had a similar experience and what was the resolution of the problem?
Do I have a valid issue that is actionable with respect to the dealer's not informing me about the BSI?
Are there replacement pads/rotors that might ameliorate this problem?
Old Feb 10, 2008 | 11:11 AM
Q45tech's Avatar
Antivibration noise dampening shims are designed and manufacturered to fit SPECFIC OEM Brake PADS. They usually help non oem pads but not as much as oem.
Ever wonder why most after market pad companies don't spend the $250,000 to test and design shims for their pads on every car the composition is used [offered for sale].
The slot length and width and curved shape are the tuning along with multilayer thickness of dampening material.
This explains how some parts of the shims work to reduce noise:
http://www.scielo.br/pdf/jbsmse/v26n3/a11v26n3.pdf
http://www.aa1car.com/library/2003/bf90318.htm
Understanding BRAKE SCIENCE will be useful all your driving life!
EaglePicher Wolverine makes over half the shims used in US and 86% of Asian vehicles:
http://www.wolverine.cn/files/pdf/shim.pdf
.005"
ACTIVE MATERIAL
(Nitrile Rubber) on both outer surface is critical! Why shims should be replaced every other pad change!
Old Feb 10, 2008 | 11:30 AM
gary c's Avatar
Gilley's right about the antisqueak compound. When you guys decide to DYI
with brakepads it's important you use our site, do a search and find out all
you can about install and how to "break the new pads in!" Without doing the
breakin chances are you'll have squeaks. It takes about 15 minutes and will
allow the pads/rotors to bond with one another........do a search!
Pinkey, you shouldn't be having those issues with almost new pads/rotors.
It doesn't sound like the rotors were installed correctly or there not the correct one for your G. Find a reliable Brake/Alignment shop in your area by
talking to people and ask them to check out your brakes. You shouldn't need
to start over will all new stuff!!
SiMpLyMoDiFiEd
The FX-Spot
Dec 2, 2021 04:35 PM
Terry_G35
May 9, 2020 01:39 AM
derres
Aug 28, 2015 03:27 PM
itschuckster
Jul 25, 2015 08:07 AM
Lsantana757
Jul 20, 2015 09:08 AM
