My 350z Tein S-techs with Springmount Mod
Old Dec 29, 2007 | 09:14 AM
blkonblk17's Avatar
Here are the end results. While I was there I added 5mm spacers for the rears making my wheels from +22 offset to +17 offset, make it flush with the fender. =)
Old Dec 29, 2007 | 09:21 AM
JOKER's Avatar
CLUB MODERATOR
looks good
Old Dec 29, 2007 | 02:26 PM
98intrigue's Avatar
I swear that looks the same ride height as mine...and I'm on 350Z Tein H-techs without the spring mount mod. I have 350z Tein S-techs sitting here....but it almost looks like there's no point in switching.
Old Dec 29, 2007 | 03:26 PM
Calvin's Avatar
Overglorified Altima
It depends on how much you both cut off the spring mount. You may have cut more off than he did, thus making your drop with the h-techs similar.
Old Dec 29, 2007 | 03:37 PM
Jason@Riverside's Avatar
nice!
Old Dec 29, 2007 | 03:47 PM
O HELLA OEM's Avatar
sick
Old Dec 29, 2007 | 04:02 PM
blkonblk17's Avatar
Well with the Z stechs the rear naturally sits a little bit higher than the front and didnt like the look thats why I did the spring mount mod and I didnt cut more rubber off because if I did then my rear was going to be lower than my front. Essentially before I did the springmount mod I could stick two fingers between the fender and the tire. After the springmount mod I reduced it to a 1 or less gap. Which is exactly what I wanted.
Old Dec 29, 2007 | 06:34 PM
w0ady's Avatar
fgc moderator
still looks high for s-techs i think. im used to them tucking tire. my z h-techs are about 1 finger gap on both wheels.
Old Dec 29, 2007 | 11:57 PM
blkonblk17's Avatar
really don't know then because stechs are supposed to drop more then the htech and the stechs are famous for not lowering the rear much. In my case it all worked out because I am now where I originally wanted to be. Thanks to the springmount mod...
Old Jan 2, 2008 | 06:16 PM
98intrigue's Avatar
My springmounts have not been modified at all...just the 350Z Tein H-techs.
I took this a few hours ago and overexposed it so you can see how much gap I have.
Old Jan 2, 2008 | 06:35 PM
App6MT's Avatar
Littering and...
What size are your tires and are your fenders rolled? Thanks
Old Jan 2, 2008 | 07:49 PM
G-MENTED's Avatar
the rear gap is fricken ugly if you dont do the mod.
Old Jan 2, 2008 | 07:54 PM
gary c's Avatar
Nice......your coupe sits "Just Right!" What suspension mods are you intending to do? I assume you had the alignment checked.....or not!
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
KruZZe
Feb 27, 2023 05:04 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
