how much lower should i go?
Old Jan 2, 2008 | 11:33 PM
black_sedan's Avatar
well... i really dont want to do it, but i need to lower my car again. im currently running the 350z unrevised suspension.
my options
TEIN s-tech 2.0F 1.3R
Eibach sportlines 1.6F 1.6R
Tanabe GF 1.5F 0.9R
I have no desire to do coilovers, although i know it will give me the ultimate in height adjustment.
Old Jan 2, 2008 | 11:40 PM
Boston's Avatar
The Tanabe is going to give you the least amount of camber issue. I'm assuming if you aren't considering coilovers then price is an issue. If that's the case then you don't want to do a camber kit either. Even with a 1.5 drop in the front, I don't think you're going to get to spec on the alignment. Good luck and post your pics with the new drop.
Old Jan 3, 2008 | 12:03 AM
perry05G35's Avatar
+1 for the tanabe.
Old Jan 3, 2008 | 01:17 AM
G35Papa's Avatar
Save your money and get the coilovers. If you're considering a second drop, chances are you still won't be satisfied till you get exactly what you really want. Tein Basics are less than 1K and will give you the height adjustability you want.
If you care about the wear on the tires, just about anything beyond 1" will require a camber kit to get back/close to OEM.
Old Jan 3, 2008 | 01:32 AM
5150DS's Avatar
Tein 350z h-tech will get you 1.28 front/1.16 rear.
Old Jan 3, 2008 | 09:48 AM
FlyingLumpia's Avatar
350z h-techs might give you the rear looks lower than the front look. Also look into H&R springs. Maybe run some d-specs to tighten it up some.
Btw what are those wheels and specs.
Old Jan 3, 2008 | 09:57 AM
SFLG35's Avatar
FGC President
to the ground!!
stechs would be your best bet
if you dont want to save for coilovers
Old Jan 3, 2008 | 10:00 AM
Boston's Avatar
+1 on the Basics. I think you'll be happy with the results. JCS Speed had the best prices on Tein Basics. I'd do the camber kit install while you're at it. In the long run it will save on irregular tire wear after the drop. Like the old commercial said, "You can pay me now or pay me later". It might be more money than you want to spend up front but worth it later. You can get the Basics and SPC kit for about $1300.00 for the parts.
Old Jan 3, 2008 | 10:02 AM
Gilley's Avatar
I have the 350z S-Techs on my sedan now. The rear is dropped way too much compared to the front. The front sropped some, but the rear is tucked. That's why I'm looking for other springs.
As far a coilovers go, I have a set of BC Racing BR coilovers on my coupe and they are a great deal for the money. There's a company on my350z.com selling them for $999.
Old Jan 3, 2008 | 05:01 PM
jonnVQuest's Avatar
Originally Posted by perry05G35
+1 for the tanabe.
X2
Old Jan 3, 2008 | 06:05 PM
Boston's Avatar
Another good option noted by Gilley. I think MSRP is between $1150-1200 and they are fully adjustable dampners.
Old Jan 3, 2008 | 07:00 PM
im not sure id like to keep my G. if i put a set of springs on it, i probably will just leave them in when i sell it. now, if i decided to do coilovers id go with a set of Tien basics. i see them for cheap all the time, but i really dont want to take the suspension apart again. i definately wont want to leave coilovers in the car when i trade it.
The wheels are Lorenzo 1 piece Forged wheels. 20x8.5 +38mm offset with 225/35/20. I need to go with a 245/35/20 since the tires have a little stretch on the wheel.
Old Jan 3, 2008 | 08:07 PM
citymunky's Avatar
Those rims look better than the OEM 19" you were going buy from me
Get the Tanabe springs.
Old Jan 4, 2008 | 01:57 PM
I ended up with a set of coupe 19s as well.
How is VA Beach treating you?
Old Jan 4, 2008 | 07:53 PM
citymunky's Avatar
^ The roads here suck(pot holes, random dips in the road, "speed bumps" on high way exits),it's cold, & the cops hunt for military.
