Road Noise (positive camber?)
Old Jan 15, 2008 | 03:12 PM
Get Some's Avatar
Has anyone found the magic key to fixing the road noise problem? Any luck with adding more positive Camber to front wheels?
Old Jan 15, 2008 | 04:21 PM
redlude97's Avatar
what tires are you using? There is no way to dial in positive camber on the front without aftermarket adjustable a-arms
Old Jan 15, 2008 | 04:31 PM
Q45tech's Avatar
Avoiding directional tread tires and flip rotate tires to reverse wear heel toe feathering.
Old Jan 15, 2008 | 04:40 PM
Get Some's Avatar
yea I was hoping some one had front camber kits and found the correct amount of camber to add. These cars keep eating up tires even if you keep them in check. The car has too much negative camber from the dealer for track driving. That and the suspention oscillation on the tire causes the feathering of the tire. If any one has added positive camber please share
Old Mar 21, 2008 | 10:06 PM
coupes-r-tits's Avatar
ebay has a few kits for front and rear camber adjustment. Anyone think they are worth it? The front kit cost like 350 on ebay. And the rear you can get for under a hundo.
Old Mar 25, 2008 | 03:30 AM
Invalid_User's Avatar
^never seen you around.....
Old Mar 25, 2008 | 07:53 AM
thats cause I'm "sneaky-sneaky" LOL
Old Mar 25, 2008 | 11:46 PM
PTownG's Avatar
since when is the key to tire noise changing suspension settings?
Old Mar 26, 2008 | 10:55 AM
he might be refering to tires being worn out faster because of negative camber resulting in more road noise coming through the worn out tires. just my 2 pennies!
Old Mar 26, 2008 | 12:21 PM
G35sedan03's Avatar
^^ coupes describe your car. i've never sen you around either.
Old Mar 26, 2008 | 01:00 PM
thats prolly cause I'm in brandon most of the time. But u can see my car I'd u go into the "check out my wheels" subforum. My thread is new sevas on the g. Its a tiny and crappy pic.
Z1Motorsports
Suspension-Vendor
56
May 31, 2020 01:56 PM
snic09
Nov 8, 2017 01:46 PM
MyfistYourFace
Aug 8, 2015 11:58 AM
johnjohn077
Audio/Video/Electronics
Aug 5, 2015 03:09 AM
Thaaa_king
Jul 18, 2015 05:56 PM
