S-Tech or H-Tech?
Old Jan 28, 2008 | 08:22 PM
Sbeck's Avatar
Alright thanks. So your saying buy S-Techs along with an Eibach rear camber kit? What exactly will this prevent?
Old Jan 28, 2008 | 08:30 PM
MIA BlazinVQ's Avatar
brb getting cut
Since we're on the topic.... The alignment should be done 3 weeks after you slap on the springs? I'm also going to put my new wheels/tires
at the same time my springs are going on. No alignment needs to be done at that time?
Old Jan 28, 2008 | 08:31 PM
Sbeck's Avatar
What springs are you getting?
Old Jan 28, 2008 | 08:32 PM
brb getting cut
sig says it all. 350z s-techs.
Old Jan 28, 2008 | 08:33 PM
brb getting cut
Oh and to answer this... a camber kit will allow you to adjust camber. lol, thus reducing any excessive tire wear, thus keeping the money in your pockets.
Old Jan 28, 2008 | 08:34 PM
Sbeck's Avatar
Alright thanks. Are there camber kits for front and rear? And i guess hes saying only get the rear?
Old Jan 28, 2008 | 08:37 PM
brb getting cut
Yeah there are kits for both F & R. I believe he suggested rears only because the rear tires go out faster than the fronts, but I could be wrong.
Old Jan 28, 2008 | 08:38 PM
Sbeck's Avatar
I've seen alot of different prices for these. How much would i expect to pay for the rears...or both if necessary.
Old Jan 28, 2008 | 08:40 PM
brb getting cut
I think rears are much cheaper than the fronts for some reason. I remember the price being roughly around ~$150 +/- plus installation (rears only).
Old Jan 28, 2008 | 08:46 PM
Sbeck's Avatar
Alright. Thanks for your help. If anyone knows for sure i'd appreciate your input =)
Old Jan 28, 2008 | 08:54 PM
The-Dream's Avatar
No drop "requires" camber kits, its your choice if you want them or not. To sum things up, the front camber is not adjustable on our cars, coupe s-techs, 350z h-techs, and 350z s-techs will put the front camber out of OEM spec for camber. This may or may not lead to excess camber wear depending on your driving etc. G35 h-techs may not put you out of spec in the front, but don't expect much of a drop if at all, the springrates also suck. For the rear alignment, 350z h-techs without a springmount mod will usually be back in specs with an alignment, for coupe or 350z s-techs, most people cannot get the rear back into spec. Once again, this can lead to camber wear for some people. My advice? Purchase the rear eibach(SPC) camber kit no matter what springs you install. The kit is relatively cheap compared to tires($150), and will pay for itself much sooner than the front camber kits which are $300+.
How's the G35 H-Tech's sprng rate compared to stock?
Old Jan 28, 2008 | 09:10 PM
Sbeck's Avatar
What do you mean by spring rate? From what ive heard its not even worth getting h techs b/c they dont even offer a noticeable drop.
Old Jan 28, 2008 | 09:13 PM
redlude97's Avatar
Oem linear springs
G35 coupes with oem 17’s & 18’s
G35 sedan’s with sport suspension
350Z’s 2003/2004
Front:314 Rear:342
Oem linear springs
G35 sedan's with non sport
Front: 283 Rear: 308
Oem linear springs
G35 coupes 2005/2006 with oem 19’s only
350Z 2004.5 to 2006
Front:314 Rear:427
Tein S-tech 350z (fronts are progressive, rears are linear) .7”/.6” drop on 350Z G35 drops will be higher
Spring rates in LBS 386/402 (estimated front intial rate is 327lbs)
Tein H-tech 350z linear springs .3”/.2” drop on 350Z G35 drop will be higher
Spring rates in LBS 358/375
Tein H-tech G35 coupe & sedan(fronts are progressive, rears are linear)
Spring rates in lbs 324/260 (final rates only, softer intial front progressive rate unknown)
Tein S-tech G35 coupe & sedan (fronts are progressive, rears are linear)
Spring rates in LBS 358/274 (final rates only, softer intial front progressive rate unknown)
They are softer than stock for both nonsport/sport suspensions
Old Jan 28, 2008 | 09:16 PM
Sbeck's Avatar
Redlude. So what do you suggest i buy for my coupe after i put 19's on it. I want an aggresive but not slammed drop and limited tire wear.
Old Jan 28, 2008 | 11:43 PM
  #30
The-Dream's Avatar
Oem linear springs
350Z’s 2003/2004
Front:314 Rear:342
Oem linear springs
Oem linear springs
350Z 2004.5 to 2006
Front:314 Rear:427
I bought the H-Techs but haven't installed them yet. Should I be expecting a much softer ride? I don't know much about spring-rates.
