S-Tech or H-Tech?
Old Jan 29, 2008 | 12:49 AM
  #31
redlude97's Avatar
Originally Posted by Sbeck
Redlude. So what do you suggest i buy for my coupe after i put 19's on it. I want an aggresive but not slammed drop and limited tire wear.
I would go with 350z h-techs and a springmount mod. Thats what I run, and I only have a rear camber kit. Drop is noticeable enough for me, but not too low that I scrape everywhere. The camber wear is also not too bad
Old Jan 29, 2008 | 12:51 AM
  #32
redlude97's Avatar
Originally Posted by fullvietFX
I bought the H-Techs but haven't installed them yet. Should I be expecting a much softer ride? I don't know much about spring-rates.
I personally wouldn't even bother installing g35 h-techs, the springrates are way too soft and the drop isn't even noticeable. Go with at least 350z h-techs, most consider that the minimum amount of drop necessary for these cars
Old Jan 29, 2008 | 01:59 PM
  #33
AccordinlySlo's Avatar
I plan on going with the 350z H-Techs. A lil drop is good enough for me. Also I plan on running DUBs on my car once its time to go rim shopping.
Old Jan 29, 2008 | 07:36 PM
  #34
MIA BlazinVQ's Avatar
brb getting cut
Originally Posted by MIA BlazinVQ
Since we're on the topic.... The alignment should be done 3 weeks after you slap on the springs? I'm also going to put my new wheels/tires
at the same time my springs are going on. No alignment needs to be done at that time?
anyone?
Old Jan 29, 2008 | 09:37 PM
  #35
Sbeck's Avatar
What does the springmount mod do? And do you NEED a camber with 350z h techs? Once again, i dont want a slammed car but i want people to be able to say, oh that car is dropped a little bit and i want it to look somewhat aggresive.
Thanks for you help.
Old Jan 29, 2008 | 10:11 PM
  #36
bigc's Avatar
Wings Nation
^ the springmount mod allows you to lower the rear of the coupe up to an extra 3/4". this is accomplished by cutting down the rubber bump stop that the spring rests against. if you take off your wheel, you'll see that there's a conical, rubber thing at the top of the spring - this is the spring mount. you can lower the car a bit more by shaving a bit off the top.
you should at least get a rear camber kit with z htechs, especially if you do the springmount mod.
Old Jan 29, 2008 | 10:13 PM
  #37
bigc's Avatar
Wings Nation
anyone?
wait a week or two to let the springs settle. they don't settle much, but the geometry changes enough to make getting an alignment right away pretty useless.
firestone does a lifetime alignment deal which is pretty useful. +/- $129 and you can get alignments done anytime.
  #38
Sbeck's Avatar
Will htechs with a rear camber be a good enough drop? without the springmount mod? Will it be noticeable?
Old Jan 29, 2008 | 10:17 PM
  #39
bigc's Avatar
Wings Nation
a "good" drop is a matter of personal taste. however, i would definitely recommend doing the springmount mod if you're going with zhtechs. it will be noticably lower, but not too low
Old Jan 29, 2008 | 10:20 PM
  #40
Sbeck's Avatar
Well what is the benefit of a springmod over just getting S-Techs with a rear camber?
Old Jan 29, 2008 | 10:55 PM
  #41
bigc's Avatar
Wings Nation
stechs drop lower than htechs + springmount mod. its all a matter of personal taste.
btw, having a rear camber kit does not affect how low the car sits. its just to adjust your alignment / camber.
Old Jan 29, 2008 | 10:58 PM
  #42
Sbeck's Avatar
Do you think that a rear camber for some S-Techs would be sufficient in reducing tire wear or will i need front too? Also spending less money would be nice =)
Old Jan 29, 2008 | 11:15 PM
  #43
bigc's Avatar
Wings Nation
from what i've read on the forums you should get a front kit if you're going with S-techs. i have z htechs so I can't speak from experience.
Old Jan 29, 2008 | 11:21 PM
  #44
brb getting cut
Hey SBeck, check out this thread to help you out in your final decision. I think one of those guys is running Super Rozzas + S-techs, too.
https://g35driver.com/forums/showthr...ghlight=s+tech
Old Jan 30, 2008 | 06:48 AM
  #45
Sbeck's Avatar
Thanks
