so what's the skinny on rear camber kits?
Old Mar 6, 2008 | 12:13 AM
redlude97's Avatar
http://www.ajusa.com/details/index/2....50L%20V6%20FI
Does this one work? If not, just search for the Part #: EIB 5.72050K
Old Mar 6, 2008 | 12:19 AM
Calvin's Avatar
Overglorified Altima
i just realized ajusa is 5 mins from my house.
but they're prices on spacers aren't exactly the best...
okay, back on topic.
Old Mar 6, 2008 | 12:21 AM
redlude97's Avatar
Really, their prices on the eibach spacers are comparable to most other sites I've checked, where are you finding them form cheaper, I may need to order a new set soon
Old Mar 6, 2008 | 12:22 AM
Stinkfist480's Avatar
^^^link is broken.
as cheap as the rear arms are, i would definitely invest in them.
as for the fronts, if you want no gap...then i'd also suggest getting front camber correcting arms. spl and 350evo both work well.
Appreciate the response..my point is, I don't want to get a camber kit just because it's inexpensive. If I were to lower the car and eliminate all fender gap, I want to know if I will "definitely" need the kit or just "might". That will determine if I will buy before or after an alignment attempt.
Old Mar 6, 2008 | 12:28 AM
redlude97's Avatar
For optimal alignment specs, you WILL need camber kits if you plan to drop that low
Old Mar 6, 2008 | 12:34 AM
Ok, thanks for the confirmation! Will that kit you mentioned cover everything I need? I keep reading about camber arms, toe bolts, etc...
Old Mar 6, 2008 | 12:37 AM
Calvin's Avatar
Why do you need to order a new set soon? What's wrong with yours now? Or do you just want bigger/smaller ones? Mine were bought locally.
BTW - I'm looking at AJUSA's site and I can only find 5mm Eibach spacers ($61). Unless you have a problem with Ichiba, OptionImports has 5mm Ichiba spacers for $53.
Although not much cheaper, TheNismoShop carries 5mm Eibachs for $60 - LOL. You can save a whole dollar!
the kit hai linked comes with rear camber arms and toe bolts.
Old Mar 6, 2008 | 12:39 AM
^^^^ Great, thanks for the info!
Old Mar 6, 2008 | 01:16 AM
PTownG's Avatar
SPC gave me an RA as soon as I got them on the phone. They were really good about it and totally understood the situation.
I ended up buying these:
http://cgi.ebay.com/ebaymotors/Ichib...spagenameZWDVW
They should be here tomorrow. I'll post how well they turn out
socalg35x
Aug 7, 2015 09:36 AM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
beevanhuynh
Jul 23, 2015 01:37 AM
nascarbuff17
Jul 16, 2015 10:23 AM
