Sway Bar End Links
Old Mar 24, 2009 | 05:36 AM
  #31
G35 Mass's Avatar
Originally Posted by 06PlatinumG
You can save your money if your not lowered, you shouldn't need to replace the end links right away. If you are lowered you are preloading the sway and need the adjustable links.
I don't believe that is correct. Since both sides are connected to wheels that are both lowered, there shouldn't be any more tension on the endlinks that if the vehicle is at stock height. The sway bar endlinks are only under tension when one side of the vehicle is compressed differently than the other, such as when cornering.
But correct me if I'm wrong.
Old Mar 24, 2009 | 06:06 AM
  #32
SDGenius's Avatar
nah, there's still pre-load at a hault(after a drop). the OEM's become too long.
Old Mar 24, 2009 | 06:07 AM
  #33
G35 Mass's Avatar
I'm not totally doubting you, but if both sides are raised up from a drop....
I'll have to do an experiment when I replace mine. I've had them sitting on a shelf for over a year.
Old Mar 24, 2009 | 11:36 AM
  #34
Klubbheads's Avatar
The endlinks are attached to the metal bracket that is attached to the frame. The actual swaybar is attached to the frame as well via bushings. So no matter how much u lower and raise the car the distance from the frame and any swaybar component will stay the same. You can not get any more perfect than OEM if the bar is installed correctly.
Old Mar 24, 2009 | 01:28 PM
  #35
OCG35's Avatar
There seems to be some confusion about adjustable endlinks… lowering the car does negatively affect fixed length endlinks – adjustable allow the link to stay perpendicular and not cause binding of the ball joint.
This DIY vid explains briefly (starting at 1:20) http://www.infinitihelp.com/diy/gsed..._procedure.htm
I was on Pro Kit and OEM endlinks were angled – then dropped further on Sportlines (didn’t even bother to see what the OEM endlinks would be like on them because I new they would be way out-a-whack) – so I switched to adjustable – they were set to be as perpendicular as OEM would be at OEM height (however, I’m nearly 2” lower than OEM now).
The vid will help understand (obviously not my vid btw).
Old Mar 24, 2009 | 01:36 PM
  #36
Jeff92se's Avatar
Red Card Crew
Fronts are attached to the control arm and that angle is affected by ride height:
Old Mar 24, 2009 | 01:51 PM
  #37
Klubbheads's Avatar
it looks like the instalation on my front endlinks was not done correctly. That is the reason i never stopped having problem with them.
Jeff I was talking about the rear endlinks but you are right the front ones can be affected by the ride height.
Old Mar 24, 2009 | 02:03 PM
  #38
WILLIE BEANS's Avatar
Learned something new today ..
Thanks guys .
Subscribed
Old Mar 24, 2009 | 02:10 PM
  #39
G35 Mass's Avatar
Angles on the joints. Gotcha. Makes sense
Old Mar 24, 2009 | 02:23 PM
  #40
Jeff92se's Avatar
Red Card Crew
I think the rears are also affected. The upper endlink mount is attached to the bottom portion of the upper A-arm. The lower A-arm houses the spring. If a lowering spring brings the upper/lower A arms any closer then I think the endlink length could be an issue.
Old Jun 15, 2009 | 12:37 PM
  #41
prj3ctm4yh3m's Avatar
endlink question
Originally Posted by Klubbheads
I never got the car handle the way it was supposed to when i switch to aftermarket Endlinks.
Hey I was just curious what you meant by this. How did the car handle? Im deating on whether i need aftermarket endlinks. i have hotchkis sways and bc coilovers with a mild drop.
thanks!
Matt
Old Jun 15, 2009 | 02:04 PM
  #42
Beebo's Avatar
Not really unless you always track the car
Old Jun 28, 2009 | 05:11 PM
  #43
425skyline's Avatar
So went under to adjust the end links a bit, since the car got raised a bit and I wanted to make the bar more parallel to the ground when in normal position. Put the wrenches on to loosen the end link and pow... I got the PowerGrids and never touched them after installing them and having them professionally adjusted/checked soon after.
I hope I can get a replacement. And to all others: careful with these, apparently they can be a little fragile.
Attached Thumbnails Sway Bar End Links-photo-3-.jpg   Sway Bar End Links-photo-4-.jpg   Sway Bar End Links-photo-5-.jpg
Old Jun 28, 2009 | 08:47 PM
  #44
Vrod-Mike's Avatar
I have them on my car. I hope mine hold up better then that. Especially since they're not cheap.
Old Jun 30, 2009 | 01:28 AM
  #45
Beebo's Avatar
Which did you buy?
