FYI: Brake Fluid level, SLIP, VDC AND EBrake lights staying on
Old Mar 23, 2008 | 03:19 PM
elrooko's Avatar
Just an FYI Folks. Was bleeding my brake lines and the fluid level was half way between min and max. Started the car, SLIP, VDC and ebrake lights all stayed on. Began to freek out - then I remembered the site motto:
"Stay Calm, Don't panic, just use the **search**"
and sure enough stumbled across a thread in the Coupe forum. Filled up the brake fluid to max and the lights turned off. A bit ballsy of Nissan to throw a code for the fluid level not being at the MAX level. They should have just said "FILL LINE" and not given an option.
Thanks again, g35driver - just wanted to let everyone know in case someone else has this issue.
Old Mar 24, 2008 | 07:29 PM
Jeff92se's Avatar
Red Card Crew
I think it's a good idea. If you get your level too low, I bet it wrecks havoc on the VDC/Traction control systems if they operate with little or no fluid. ie.. pumping a bunch of air would be baad.
laksjd84
Feb 28, 2026 01:58 PM
Hasanbaloch
Feb 29, 2024 08:45 PM
Mry
Mar 3, 2023 01:03 AM
Wayne9011
Jul 27, 2015 11:25 AM
mushu
Jul 15, 2015 03:55 PM
