What do you think of my alignment specs?
Old Mar 26, 2008 | 01:05 PM
MIA BlazinVQ's Avatar
brb getting cut
I got my alignment done at the stealership yesterday due to me dropping the car on Z S-techs. This is without any camber kits:
Front Left:
Camber: -1.7
Caster: 7.8
Toe: 0.04
SAI: 5.6
Included Angle: 3.9
Front Right:
Camber: -1.8
Caster: 8.3
Toe: 0.04
SAI: 5.5
Included Angle: 3.8
Front:
Cross Camber: 0.0
Cross Caster: -0.4
Cross SAI: 0.1
Total Toe: 0.09
Rear Left:
Camber: -1.5
Toe: 0.10
Rear Right:
Camber: -1.7
Toe: 0.10
Rear:
Cross Camber: 0.1
Total Toe: 0.20
Thrust Angle: 0.0
Now... I know the OEM specs are a very wide range but the guy managed to get the rear barely into specs. I figured I'd see just exactly how long these
tires are going to last me. If they end up getting worn out very quick obviously I'll get the camber kit. You can call me the experiment to S-techs without camber kits.
Old Mar 26, 2008 | 01:09 PM
MikeYo's Avatar
Hopefully you get some possitive results... I'm looking to do the same thing
Old Mar 26, 2008 | 01:44 PM
GreenGoblin's Avatar
The goblin resurrection
I had the s-techs for a year with nothing done no problems with me
Old Mar 26, 2008 | 01:46 PM
Calvin's Avatar
Overglorified Altima
i'd get that toe as close to 0 as possible if you want your tires to last as long as possible.
Gdup35sedan's Avatar
ENVautoDetailing.com
alignment looks pretty good.
-GP-
Old Mar 26, 2008 | 02:04 PM
redlude97's Avatar
The rear toe is a little high still, aim for 0.05 but then your camber won't be adjustable. Did you do a springmount mod in the rear? My guess is no
Old Mar 26, 2008 | 02:35 PM
Q45tech's Avatar
Tires are designed for a negative -0.5 degrees camber maximum to meet oem tire mileage goals.
Old Mar 26, 2008 | 02:50 PM
brb getting cut
yup you guessed right. I'm debating whether I should let cruisngcoupe do it for me. I dont want him facking up my springmount. haha jk danny
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
Dallsinghjr1
Sep 17, 2023 11:25 AM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
Picture Share
Feb 4, 2018 12:41 PM
prinny
Nov 22, 2015 11:07 PM
