Would this look homoz?
Originally Posted by Jeff92se
Shocks and springs?
On the rear it's just two extra bolts to take off and you done.
So easy.
Don't even have to use spring compressor.
Originally Posted by JOKER
what do you have now?
Front springs from F150?
Why is it so hight up like that?
And if you end up doing something "homoz" just park next to TITOs car when you attend meets and your car will look exceptionally awesome.
Philly. Cool. but I'd never get into my driveway like that lol.
Actually the front isn't THAT bad. There's a crown in the road and it somehow made the front look worse.
Seriously I would do it all in one shot. Start with the fronts, the back are cake and shouldn't take you more than half an hour to an hour. I have had mine apart a couple of times.
I did strip a bolt on the front suspension using a 12 point socket. I went out a bought a full set of 6 point sockets to avoid that in the future.
I "think" have a set of extra strut tops for the fronts. If so, it will be alot easier. I can pre-assemble the fronts and swap.
I'll be using this guy's instructions. http://www.my350z.com/forum/showthread.php?t=318335
Where do you guys put your jack stands anyway?
