BC Racing vs JIC FLT-A2 Coilovers
Old Apr 18, 2008 | 11:48 AM
  #46
Klubbheads's Avatar
Originally Posted by Skyline_G35
Hey, glad you got them on. Where or what type of alignment shops do the corner balancing? Or do you need a performance shop for that? Thanks.
alignment is here local called West End. He is very oldschool and uses no electrical equipment to align the car. He also does corner balancing. I would thing most high end alignment shops who align high end cars should have corner balancing equipment.
Old Apr 18, 2008 | 11:49 AM
  #47
Klubbheads's Avatar
Originally Posted by dofu
I have the JIC VIP, the difference between these and the FLT-A2 for the coupe is softer spring rates. Handles great, and feels great. Actually one of the best handling suspensions I've tried so far... As most of the better suspension companies, you can order custom spring rates and specs from JIC too.
what else do u have on ur car?
Old Apr 18, 2008 | 05:02 PM
  #48
dofu's Avatar
20 Year Member
Shorter, adjustable tie rods and tie rod ends. Tie bars, strut bar, sways... just about everything when it comes to suspension.
Old Apr 19, 2008 | 10:09 PM
  #49
dreyG35's Avatar
JIC FLT A2 for sale
Hey, JIC's are awesome!! They're perfect if your a drifting type of driver
I have some that I might sell for a pretty cheap price compared to brand new price!!...PM me if interested
Old Apr 21, 2008 | 04:41 PM
  #50
SDGeneralCounsel's Avatar
just to let you know
Another Time Attack Victory for Relentless!
Round #2 of the 2008 Redline Time Attack Series is in the books and Relentless Autosports chalked up two more podium finishes!
The event was held at Gateway International Raceway near St. Louis and Relentless Autosports owner, Scott Bush was on hand driving BC Racing North America's brand new time attack Infiniti G35 Coupe.
This time attack G35 features a Relenltess Autosports VQ35DE Race Motor!
Scott and the BC Racing NA G35 were able to take home 1st Place in Unlimited RWD and 2nd Place in Modified RWD despite a few bugs that still need to be worked out on the brand new car.
Old Apr 21, 2008 | 04:44 PM
  #51
Klubbheads's Avatar
WooohoOOOO!!!!! I can't wait to get this thing corner balanced and aligned this coming friday!.
BTW i was driving on the softest setting rear and front and my cousin who knows absolutely nothing about car's told me how much softer and more confortable the ride was compared to the S-techs that i had. My sister today told me the same thing today when i was taking her to school.
Old Apr 21, 2008 | 05:19 PM
  #52
D&G35's Avatar
JICs FTW!!!!!!
Old Apr 21, 2008 | 05:20 PM
  #53
Klubbheads's Avatar
Originally Posted by D&G35
JICs FTW!!!!!!
good driver knowing the limits of the car is FTMFW!
Old Apr 21, 2008 | 06:03 PM
  #54
shabarivas's Avatar
umm solid bro... FLT's are wayyy better than BC's... depends on how much you wanna spend and if you are gonna be tracking the badboy...
Old Apr 22, 2008 | 01:02 PM
  #55
Jeff92se's Avatar
Red Card Crew
Wouldn't that be because the rear coils are actually softer than stock?
Old Apr 22, 2008 | 01:05 PM
  #56
Klubbheads's Avatar
no because the shock allows the spring to compress a lot more there for giving the driver the impression that the car is softer and more forgiving over ruff surfaces.
Old Apr 22, 2008 | 01:44 PM
  #57
Jeff92se's Avatar
Red Card Crew
I noticed the spring rates were the same as oem or softer on either the front or rear. I asked about it but got no answer. Would like to know just for my reference.
Old Apr 22, 2008 | 06:13 PM
  #58
Klubbheads's Avatar
based on my calculations the fronts are 10kg/mm = ~560 lb/in and the rears are 8kg/mm = ~448 lb/in.
Hope it helps.
Old Apr 22, 2008 | 06:31 PM
  #59
Jeff92se's Avatar
Red Card Crew
Here's what I get: dunno of oem on the Tein Basics mean oem spring rates. But seems ball park. Depends on if we are comparing the revised versions? Dunno of the coupe got revised stiffer springs. But the Z eventually had 427 lb units?
So it seems these are very close to some oem spring rates. At least in the rears. Maybe 5% over let's say the revised Z rear springs?
Tein Basics
DSP26-LUAS2 INFINITI G35 2003-2006 ; exc G35X
9/9 kg OEM
-1.6~-3.7/0~-1.4
Tein Basic (twin tube construction, non adjustable dampners )
Spring rates 504/504
Stiffer then oem by F+61% R+43%
Transfers +18% roll stiffness to front
BC Racing Type BR Coilover
10/8k spring rates
46mm internals (53mm shocks!!!)
1 year warranty
30 way adjustable
fixed cup design
Old Apr 22, 2008 | 06:37 PM
  #60
Klubbheads's Avatar
Yes, the BC rear springs have softer rates than tein basic's rear springs. If that is ur question then the answer is yes.
