Brake bleeding. Perferred method?
#31
Originally Posted by Da-G-SpoT
Why would you activate your ABS with bleeder open? When you are doing the pump procedure do you have someone pump the brake while your bleeder is open??? No, so you CLOSE your bleeder before you activate the ABS, then when its done activating and dis-activates you can OPEN the bleeder. . Even though it would be funny to see someone do that, its just..... dumb.
#32
on
The facory service manual specifically staets to disconnect the VDC/ ABs, or negative battery cable, when bleeding also lists the proper order as rt rear, then left front, , left rear, and fnally the rt front. Also with the vehicle sitting still no wheels will be turning at differnet rpm, so ABS would not activate.
#33
bringing back an old thread since im going to be bleeding the G's brakes
soon using the griot's extactor and mityvac replenishing bottle...
since im not going to be pumping the brake pedal to do this, i can do
the bleeding while the car is completely turned off right? no need to do
anything. just setup my gear and bleed.
(griot's manual says to turn the car ON and place in "D" , pump the
brakes 2 times or something)... ??
#34
#38
#40
#41
everything went well.
here's my setup. Griot's brake fluid extractor + mityvac bottle.
Griot's includes a replenishing bottle (left one) but it's almost
just a squirt bottle. and the nozzle is too long and will
just hit the filter/spring for lid inside the reservoire if you are
planning to just place it on top. with the mityvac bottle you can
adjust the nozzle length. no issues with leaks/overflow. was
consistently at the 'max' line throughout.
was planning to do a DIY, but my camera ran out of battery...
so just went ahead without. mine are the brembo brakes, so
needed to bleed 8x like gilley stated above.
#42
#44
Never done a gravity bleed but doubt it will work on a modern car. I think you have to have some external pressure to push or pull the fluid through the system. If it did work you would be waiting a long time for anything to happen and air would probably get in without fluid under pressure coming out of the bleeder screw valve. At the least buy a one way bleeder valve hose at an auto parts store. These go on the bleeder valve and have a check valve to let fluid out but keep air from going back into the brake system.
I prefer the Griot's vacuum machine shown above, over the Motive pressure machne, which usually leaked all over the place because it could not get a good seal on the master cylinder.
#45
