OEM brembo or aftermarket JBT BBK ???
Old Apr 5, 2008 | 02:57 PM
edindaclub's Avatar
so I was thinking to get a set of OEM brembo or those BBK like the JBT 6 pistons..but OEM brembo is gonna cost me around 2k with rotors and everything used..and JBT will cost me 3k but its brand new(6 pis/355/4 pis/340).... or prehaps I should get the auth kenstyle front first since I alreayd got the IMPUL sides.... and is the OEM brembo gonna make a Day and Night differences ?? I got the gt-c 19s..and sometimes I had to step very hard for my brake to stop it completely.
Old Apr 5, 2008 | 03:50 PM
Beebo's Avatar
get the kenstyle front... i would like to see how it looks with impul sides
i have an 05 and have driven an 04 with brembos and couldnt tell much of a difference between them... not worth it IMO
Old Apr 5, 2008 | 04:08 PM
xjonmo's Avatar
not much of a difference in normal stopping power unless you track your car
i would invest in the jbt if i had to pick
Old Apr 5, 2008 | 05:33 PM
edindaclub's Avatar
thanks for the feedback..guess i'll have to save up for some JBT
Old Apr 5, 2008 | 06:53 PM
HenryLee's Avatar
JBT for sure.. brembos are mostly for looks unless your track your car.. but got to love the gold brembos..
Old Apr 5, 2008 | 07:56 PM
mwarsh1's Avatar
Brembo Brembo Brembo!
Old Apr 5, 2008 | 08:33 PM
AGThing1227's Avatar
That is a sign of a bias lol. Get the JBT. The brembos are only better with heat. Although can't go wrong with either. I would buy brembos and put the extra money towrds F/I . Ha but thats not an option.
-AGThing1227
idrive_MD's Avatar
save some loot and get these from racingbrake.com:
6pot with slots
Old Apr 5, 2008 | 09:27 PM
g30wh4t's Avatar
Save 5 g's and get an apracing BBK expensive, but incredible for stopping
Old Apr 6, 2008 | 01:16 AM
Capthook's Avatar
JBT, I think nothing makes a car look better then brakes. If you get the brembos you will probl. end up upgrading.
Old Apr 6, 2008 | 04:58 AM
GreenGoblin's Avatar
The goblin resurrection
lol brembos are hardly for looks, they are tryed and tested brand, i track my car and I have yet to exceed the limits of brakes no fade with upgraded fluid, most other bbk are for show who needs a 12 pot caliper no one but it looks good
Old Apr 6, 2008 | 08:40 AM
citymunky's Avatar
+1, I say save some money and go with some OEM Brembo Capliers, and buy new slotted rotors, pads, stainless steel lines and Motul or Dot 4 Brake Fluid.
Old Apr 7, 2008 | 02:25 AM
OG35Driver's Avatar
I have to agree with citymunky, just get the 2 piece "slotted aero rotors" from Stop Tech. SS lines can be had thru Stop Tech or Goodrige. As for pads I t all depends on what you kinda performance you want. Fluid can be upgraded as well, but is really only going to make a difference if you are going to be auto-xing or tracking because it has a higher boiling point. Again, agree with the citymunky, go with the Motul if you decide to upgrade that as well.
Old Apr 7, 2008 | 07:00 PM
Jeff92se's Avatar
Red Card Crew
You need to really evaluate what you want out of your bbk. OEM brembos is a quality kit. But it's not that cheap at $2 grand used. Hell you might even look into the Akebono oem kit that someone is developing for the older Gs. Huge discs front and rear. But these two kits only have 1pc rotors. Not bad, just heavy.
The JBT kit is more expensive but it should come with 2 pc rotors. Less weight and very qualty units. New and only about $1k more? Not too bad consider what you are getting.
Old Apr 7, 2008 | 09:34 PM
citymunky's Avatar
You always could buy better 2-pc rotors and still be under 2Kwith OEM Brembo's.
That over 1K could go to Sways/Cambers kits/Springs or coilovers.
mjfenix
Aug 17, 2017 05:49 AM
Frankieg35
Mar 20, 2016 09:42 PM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
mushu
Jul 15, 2015 03:55 PM
