Will 06 Brake fits on 03-04 G or Z?
Old Apr 16, 2008 | 02:48 PM
cdxsuprace's Avatar
Hi, I just want to know if anyone have done this. I have an 06 sport coupe. Will my brake fits on an 03-04 G or Z? Also, will an 03-04 Z factory Brembo fit on my 06 G? I already asked Tony at Riverside and he said it will works but just wonder if anyone have done it.
Old Apr 16, 2008 | 08:47 PM
G SEDAN's Avatar
yes to all your questions. brakes are all interchangable between 03-07 G coupes.
Old Apr 17, 2008 | 12:42 AM
Beebo's Avatar
^^^ and Z as well
Old Apr 19, 2008 | 08:22 AM
G35CDUCK's Avatar
I know your say it works for the Coupes!
Does it work for the 03 Sedan?
is it worth the cost of up gradeing?
Old Apr 20, 2008 | 02:26 AM
Beebo's Avatar
^ yes i believe it will fit the sedans as well... do i think its worth it? No...
Old Apr 21, 2008 | 11:52 AM
Jeff92se's Avatar
Red Card Crew
I'll be doing the swap very soon and I think it will be very worth it.
Old Apr 21, 2008 | 12:25 PM
erdog's Avatar
Can someone confirm that 03 Z non brembo will fit 03 G sedan non brembo?
Old Apr 21, 2008 | 12:30 PM
redlude97's Avatar
Yes, they are exactly the same. Not sure why you would perform this "swap" though
Old Apr 21, 2008 | 12:32 PM
Jeff92se's Avatar
Red Card Crew
lol. Exactly. Maybe someone had a bbk and needs to put the stock stuff back on or something. Other than that,
Old Apr 21, 2008 | 12:57 PM
erdog's Avatar
I found some brake pads for the 03 Z and it didn't list that they fit the G as well. What I meant to ask will the pads for the Z fit the G non brembo brake system.
Old Apr 21, 2008 | 02:15 PM
Jeff92se's Avatar
Red Card Crew
Well if the brake equipment is exactly the same then it would be correct to assume the pad applications would be also.
Old Apr 21, 2008 | 04:49 PM
redlude97's Avatar
You should not assume things through reasoning, you need to ask specifically if they will fit
Old Apr 21, 2008 | 06:24 PM
erdog's Avatar
Do they, specifically, fit?
Old Apr 21, 2008 | 08:33 PM
redlude97's Avatar
LOL, YES!
Old Apr 22, 2008 | 12:51 AM
Kris79's Avatar
battle froggy
05+ rotors are larger than say like teh 03-04 g and z auto coupes and g sedans
