Brake noise
Brake noise
Whats up guys,
I have a 06 g35 coupe and when i go from drive to reverse and then back to drive and hit the brakes there is a pop that comes from my front right brake/suspension im not sure it kind of sounds like my caliper is moving and it only doese it in the morning when i back out of the garage and then i try to replicate the sound and it doesent happen? Anyone have same problem or and idea of what it could be?
I had that problem with my integra, one of the 2 bolts that hold the caliper to the rotor assembly was gone, when you go in reverse it shifts, when you go forward it goes back into place, check the bolts, make sure they are tight, take it to the dealership, your still under warr.
That happened to me the second day I had the car.
Popping noise.. metal clinging and clanging.. Eventually the front left wheel locked up completely. Dealer fixed it under warranty.
Originally Posted by infiniti06
Whats up guys,
I'm thinking maybe loose brake pads? needs shimming? Anyone know? or any ideas? I have the OEM brembos BTW.
looks like this guy had the exact problem...i'll probably try some shimming to prevent the brake pad movement.
in this thread..
https://g35driver.com/forums/engine-drivetrain-forced-induction/155649-click-sound-front-wheels.html
Originally Posted by kman23
I took my car to the dealer and he told me that the sound was due to worn out front discs on the brakes. For some reason the sound only comes when i backup. However if i backup and dont hold down the brakes i dont get the sound. It look like they are telling me the truth.
Sometimes the brake pad hardware will shift if not insalled properly previously from a brake job or sometimes from the manufacturer.
Originally Posted by ninous26
Deezflip.. You're describing the EXACT same problem I had.. Its a loose caliper bolt.. Do you hear a grinding noise while driving?
magnetism80
Feb 1, 2019 10:00 AM
