Problem with removing lower caliper slide pin
Old May 11, 2008 | 04:52 AM
The Critic's Avatar
I replaced the rear pads and resurfaced the rotors on a member's 05 5AT Sedan today. The factory service manual states that you should remove the lower slide pin and swing the caliper upward to remove the pads. However when I tried this, I could not remove the lower slide pin (I was only able to loosen it) as a suspension component was blocking the removal of the slide pin.
I am surprised that the factory recommends that I remove the lower slide pin to replace the pads--I think removing the upper pin and sliding the caliper downward is a better idea.
Has anyone experienced the same problem that I did? If so, what was your solution?
Thanks.
Old May 11, 2008 | 12:14 PM
jared2027's Avatar
I just remove the caliper bracket with caliper still attached, and then remove the caliper pin. Make sure you loosen the bolts before taking it off though.
Not sure if you had a similar problem, but I found that I couldn't get a torque wrench on the lower caliper bracket bolt. I was able to barely get one on the caliper pin at least.
skippyG
Jan 25, 2016 01:18 PM
kinetek
Aug 3, 2015 04:25 PM
Harman Singh
2nd Gen (V36) Sedan
Jul 30, 2015 03:39 PM
Frostbite91
Jul 27, 2015 05:25 AM
