HELP! At the dealership right now!!
Old May 13, 2008 | 04:24 PM
yalag's Avatar
I just took my car in to a dealership in Toronto for snow tire change. Then theybtold me I have to repalce my brake pads at 52k milage. They said it would cost 900 plus tax for front and rear. Is this right? If it is just a hundred or so more than an outside job then its fine by me but I just want to make sure it isnt somethng like 200 and they are charging me 900 for it that sort of thing. I have no idea what brembo brake pads are suppose to cost.
Old May 13, 2008 | 04:30 PM
Meatshackle's Avatar
Deep Sea Moderator
That seems high to me. I replaced my rotors and pads for less than that. They must get a grip for labor.
Old May 13, 2008 | 04:36 PM
yalag's Avatar
so how much should it be....**** they are already working on of as I type this...
Old May 13, 2008 | 04:52 PM
jdmgee35's Avatar
should be around under $500, right? U should've shopped around first. Seems like they're hardcore ripping u off.
Old May 13, 2008 | 04:56 PM
brazil0525's Avatar
Yea, i was gonna replace my pads (but ended up not having to yet) and they quoted me $345 - $420 (labor included)
Old May 13, 2008 | 06:09 PM
Deep Sea Moderator
Pads only or pads and rotors?
Old May 14, 2008 | 12:16 AM
GTR_Boy's Avatar
If they are for the Brembo brake setup, then I bet the $900 would be just for replacing the pads (fronts and rears). Replacing the rotors would cost you a lot more, especially at the dealership. Coz they told me once to replace the front rotors and pads (including labour), I would be looking at about $2500. And the rears would cost about the same.
A lot of people are buying parts online at a good price and then getting it installed either by yourself or at a reputable mechanic shop, and you'll save yourself a ton of money.
I bought OEM Brembo front and rear pads for ~$200 and brought it to a shop to install for about $150.
Old May 14, 2008 | 10:11 AM
fldrummer's Avatar
Do yourself a favor and buy your own pads and have an independent shop install them. As mentioned previously, shop and ask around, and find a reputable shop.
Old May 15, 2008 | 07:31 AM
athens's Avatar
Had reputable shop install Centric Posi-Quiet Extended Wears all around and new front rotors (since rotors had previously been cut under warranty front pad replacement).
$580 including parts, labor and tax.
FYI:
The dealer I bought my coupe new from in 2003 was recently sold. New management must think they are clever. They are running a "SERVICE SPECIAL" including an oil service and tire rotation for ..... get this....... $90!!!!! This is for standard petroleum oil. Not synthetic!! Are they using gold plated oil filters??
How will they perform a standard tire rotation on the coupes? Since they sell also sell new Lamborghinis and Bentleys perhaps that's where they are developing their marketing strategy for Infiniti from.
Any JUST TIRE or NTB shop offers free tire rotation with $23.00 oil service. If you have purchased tires at those shops they provide free lifetime balancing.
Old May 15, 2008 | 12:51 PM
XBrisk202's Avatar
dude, if they're just replacing brake pads, 900 is way too much...I think the quote for replacing brake pads is like 150-200.
And either way, you should just do it yourself. Go to an auto parts store and you can probably get brake pads for about $50. you pretty much just take off the wheel, take out the screws, lift up the caliper, and pull out the pads. If you're confused, i'm sure there's a diy here...
but yeah, I'd def bail out if i were you
Old May 15, 2008 | 12:53 PM
WhosRich's Avatar
way to much. i got my pads installed at a local NAPA for 145 for just fronts. albeit i didnt get rotors or the rears, but it should still be less
Marlin84
Apr 1, 2020 12:52 PM
ChrisAult2004
Sep 11, 2015 10:33 PM
Dmill86
Sep 6, 2015 08:14 PM
UT G35
Sep 3, 2015 03:58 PM
nightowl.czc
SouthEast
Aug 28, 2015 08:36 PM
