ne1 know difference between H-Tech & S-Tech TEIN SPRINGS?
Old May 20, 2008 | 11:53 AM
minh81n's Avatar
besides the drop (H-tech = .6 & .3 and S-tech = 1.2 & .9) is there any other difference? the h-tech springs look totally different =\ freaks me out.lol
Old May 20, 2008 | 11:55 AM
Klubbheads's Avatar
h-tech = soft
S-tech = hard
Old May 20, 2008 | 12:17 PM
minh81n's Avatar
that's funny.. they should've made the H to be hard and the S to be soft.. weirdos.
so i'm guessing the S will be the better cornerings and h will be the smoother ride?
Old May 20, 2008 | 12:18 PM
Klubbheads's Avatar
exactly.
Old May 20, 2008 | 12:26 PM
Gilley's Avatar
The spring rates and drops are different. There is also a difference between H-Techs and S-Techs for the 350Z and G35. check out the suspension sticky at the top of the brakes & suspension section.
Old May 20, 2008 | 01:12 PM
redlude97's Avatar
Originally Posted by Klubbheads
h-tech = soft
S-tech = hard
This is not completely true, the s-techs have progressive front springs which could possibly be softer initially than the h-techs, and the springrates for the g35 coupe differ by only a small amount
Old May 20, 2008 | 02:26 PM
minh81n's Avatar
well i'm more worried about my shocks giving out.. with that small of a drop, if i get the camber kits for the front and rear, has anyone had any problems with shocks giving out?
Old May 20, 2008 | 07:08 PM
Gilley's Avatar
Shocks will wear out with any suspension, even OEM. Time and use wears them out.
Old May 20, 2008 | 07:20 PM
Da-G-SpoT's Avatar
^^^ True, but whats the impact of the drop on the OEM shocks with lets say... H techs VS S Techs?
Old May 20, 2008 | 10:12 PM
Beebo's Avatar
Bump...
Old May 20, 2008 | 10:52 PM
xx7sephiroth7xx's Avatar
G
bump, I'd like to hear Da-G-SpoT's question be answered, too.
Old May 21, 2008 | 12:28 AM
SteveBlake's Avatar
Most likely the lower the drop the harder the impact, you do the math.
Old May 21, 2008 | 12:39 AM
gary c's Avatar
Tein H vs S Tech Springs....?
Steve is correct, the lower the springs the more abuse the OEM shocks take.
If you'll visit Teins website it tells the difference between all the springs, and
they are ALL different....H-Tech for the G35....H-Tech for the 350Z and the
same for the S-Techs....check it out!
Old May 21, 2008 | 12:44 AM
SteveBlake's Avatar
Originally Posted by Beebo
Bump...
Wes, your stock struts should be fine with Z H-Techs if you were thinkin about gettin them.
Old May 22, 2008 | 12:08 AM
Beebo's Avatar
Cool... Cool...
Time to order...
BTW People RXmotors has the best deals so far...
EasySausage
Sep 24, 2015 01:06 PM
reavensf
Sep 17, 2015 11:30 PM
pdexta
Tuner & Dyno
Sep 2, 2015 01:03 PM
INVADER_6MT
Sep 1, 2015 10:19 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
