Bad suspension install?
Old May 23, 2008 | 11:02 PM
MNDZA's Avatar
I just got my suspension installed at one six motorsports after arecommendation here and I'm kind of concerned. First of all it was supposed to take 3-4hrs, but took a whole 7hrs and cost me $290 instead of the original estimate of $200-$250. They were drilling something and claimed the rear SPC camber kit had to be slightly modified to fit. I thought it was made specifically for the G. Also they did not install the shim kit that came with the SPC front camber kit claiming that I may not need it and that the alignment shop will determine this and install if needed. Any thoughts?
Old May 23, 2008 | 11:06 PM
BlueDevilBAMF's Avatar
It only cost you $290 to get springs, shocks and camber kits installed?
Old May 24, 2008 | 12:24 AM
MNDZA's Avatar
Yeah.....but still.
Old May 24, 2008 | 03:49 AM
EL-EE-ES's Avatar
the rear kit shouldnt have to be modified, its the hole for the toe bolt that had to be elongated so your toe can be adjusted. so thats what they had to drill out. 290 for springs, shocks and camber kit is a great price for install
Old May 24, 2008 | 07:38 AM
kenchan's Avatar
mark's a good guy. i wouldn't be concerned. get the alignment done and
see wat they say. good luck.
Old May 24, 2008 | 08:20 AM
MNDZA's Avatar
Yeah you're right it was the hole for the toe bolt. I'm just not familiar with it I guess so I didn't know. I've done a few suspension installs, but never installed a camber kit. What about that shim kit that was never installed? What's that for exactly?
Old May 24, 2008 | 07:50 PM
TurboDreamzG's Avatar
Shouldn't be any drilling needed for that install. Dont know why they would tell you that but if I were you I'd find out what they did exactly. The camber kits should just bolt right up anyways to by the way. Prolly didn't install the shims because they didn't know where they go. lol. Most people just leave theirs out though.
Old May 25, 2008 | 08:23 AM
MNDZA's Avatar
It was for the toe bolt. Now what's the shim kit for and do I need it?
Old May 25, 2008 | 08:32 AM
Glex25's Avatar
Administrator
The shim kit adds +/- 2deg of camber.
without it you will only have +/- 1 deg of camber adjustment
Old May 25, 2008 | 09:52 AM
MNDZA's Avatar
Oh ok. Thanks for the info. I'm guessing I might not need them because of the modest drop.
Old May 25, 2008 | 05:18 PM
Gilley's Avatar
Everything sounds fine to me about the installation. The drilling was for the toe bolts. Only cars with extreme drops need the SPC hub shims up front. I didn't install them on either of my G's. $290 isn't a bad price for the installation.
rezendvous420
May 31, 2020 01:26 PM
EnCr1pt3d
Jul 8, 2019 02:48 PM
itztwinki3
Oct 5, 2015 11:29 AM
CJay
Aug 1, 2015 03:57 AM
newg37
Jul 26, 2015 09:32 AM
