Am I going to rub?
Old Jun 3, 2008 | 08:17 PM
CDN_G35's Avatar
Am I going to rub?
Hey guys, I just got some 20's and they should be here in the next few days so I wanted to pick up some H-techs for that nice drop when they go on. Here's my specs. The wheels are 20x8.5 up front and 20x10.5 out back with 25+ offset. I'm running 245/35/20 up front and 275/30/20 on the back! If anyone is running this setup with any kind of springs/coilovers I would greatly appreciate a couple pics if possible. For guys that have done this and are knowlegeable about tire specs/offsets chime in please! Thanks again guys!
Old Jun 3, 2008 | 08:23 PM
CDN_G35's Avatar
Now that I think of it, I'd even be willing to run s techs as long i WON"T RUB! Thats the key hear! Keep in mind a budget as well, I'm not shy to work and have the tools so I'll be able to put them in as well.
Gdup35sedan's Avatar
ENVautoDetailing.com
You'll need a mild rear fender roll and you wont rub.
-GP-
Old Jun 3, 2008 | 08:24 PM
CDN_G35's Avatar
How much would fender rolling run me? Is there a DIY?
Old Jun 3, 2008 | 08:31 PM
look up member 'accordfreak' he did a DIY on fender rolling.
-GP-
Old Jun 3, 2008 | 08:34 PM
CDN_G35's Avatar
Thanks a lot for ur help! So you think I would rub a bit with the H-tech or the S-techs? I'm talking about the 350z ones.
Old Jun 3, 2008 | 08:41 PM
the lower you go the less chance you have of rubbing because you will get more camber. It doesnt matter if you get S-tech's or H-tech's, if they're for the G or the Z, you wont rub with a mild fender roll.
-GP-
Old Jun 3, 2008 | 08:57 PM
CDN_G35's Avatar
Thats what I wanted to hear! I just want to avoid a camber kit for the moment.. I'm on a bit of a budget I think I'll probably go with the Z h-techs.
Old Jun 4, 2008 | 06:47 AM
TurboDreamzG's Avatar
20x10.5? Yeah you might slightly rub. Like he said do the fender roll, it's a very simple diy and all it requires is some pipe and a heat gun. When you do the roll might as well just go ahead and roll them as much as you can instead of a "mild" roll just incase you decide to go lower later on. By the way here is the link to do the roll yourself: https://g35driver.com/forums/showthr...iy+fender+roll
Old Jun 4, 2008 | 07:40 AM
Gilley's Avatar
I would be more concerned about stretching a 275 on a 10.5 inch wide rim and what the lack of camber kits will do to the tires.
I used a rubber mallot (a lot of light taps) and a heat gun to roll at least 4 sets of fenders. It comes out good.
Old Jun 4, 2008 | 10:06 AM
CDN_G35's Avatar
I'm gunna attempt the fender roll today with a bat and a hair dryer (no heatgun ) I'll see how it goes. Thanks for the link on the DIY! I'm just guna take my time and do it right
Old Jun 4, 2008 | 12:14 PM
CDN_G35's Avatar
I'm rolling these badboys as we speak, all i can say is you gotta take ur time. Not as easy as some people say, you need to apply a good amount of pressure!
Old Jun 4, 2008 | 03:10 PM
05GRide's Avatar
I hope it comes out alright by using a bat or PVC piece. I'm a strong proponent of "doing it right" and having someone use a fender rolling tool on your car. Just pay attention to the outside line of your fender (looking down the car standing next to the door looking toward the rear bumper) and make sure you don't "bulge" it outwards. If you don't pay attention to the outside lines as much as the inside fender, you could get a wavy appearance when you look down the car. Good luck though!
Old Jun 4, 2008 | 04:58 PM
Def. having two people makes it much easier. I used the pvc piping. I rolled while my buddy used a heat gun, that cuts down on the aggervation of doing it yourself.
DRG35R
Jan 31, 2016 07:14 AM
Popes
Sep 28, 2015 05:14 AM
alinero718
Sep 27, 2015 09:35 PM
