Advice on new rotors/pads for 04 g35
Old Jun 23, 2008 | 02:43 AM
ShawnNik's Avatar
Brakes Advice on new rotors/pads for 04 g35
Hi,
I have a 2004 G35 with 50k on it and a mechanic told me that my rotors are pretty much gone. I personally cant tell a difference because they work great, but 50k seems about right for rotors. I have found a lot of forums talking about which perform better and have better heat distribution, but I never take the car to the track. (Got a bike for that . Can someone recommend rotors/pads for an 04 coupe with brembo brakes that work fine in regular conditions and don't make too much noise.
Thank you in advance,
Shawn
Old Jun 23, 2008 | 10:39 AM
Darkstar752's Avatar
I'm pretty sure there's some cross-drilled, slotted rotors that aren't much more and are quiet. Plus they look a lot better IMO. Do some research on them
CreativeDesignZ's Avatar
i went with R1 premium Xdrilled and slotted with Hawk HPS pads, and couldnt be any happier. 556 shipped for all 4 corners
Old Jun 23, 2008 | 03:54 PM
silver g's Avatar
I went with Hawk HPS Pads and Stillen Slotted rotors. They work awesome!!
Old Jun 23, 2008 | 04:35 PM
cant go wrong with the hawk HPS, they are great, no noise and very very low dusting
Old Jun 23, 2008 | 04:41 PM
Klubbheads's Avatar
+1 on hawk HPS. Almost 0 dust and they work great. They don't bite as hard as the stock pads but they work better with heat and will fade later. As far as the rotors, i went with stoptech drilled replacement rotors and couldn't be happier.
Old Jun 23, 2008 | 09:16 PM
InfinitiSkyline's Avatar
I went with OC Autosports cliffhanger rotors and Project Mu pads. The brake feel is the same as OEM and there is a significant reduction in the amount of brake dust on my rims.
Old Jun 24, 2008 | 12:03 AM
Sagemark's Avatar
Either drilled and slotted or just slotted look good but I'm back to solid after cracking both. Drilled and slotted on the street and slotted at the track. Probably not as much of a problem with Brembos but the smaller base brake systems can build a lot of heat if you push them.
NAPA sell both cheap and premium rotors. The premium ones are made in Italy. They look good and are heavy. I found them to be excellent and did not fail at the track even when I overheated my Hawk HP Plus pads. This was after I destroyed a cheaper pair of slotted rotors.
If stock performance is good enough for you and you aren't tracking ceramic pads are good for low dusting.
Old Jun 24, 2008 | 08:10 AM
Gilley's Avatar
If you son't have the Brembo brakes on your car, the Brembo rotors won't work.
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
DRG35R
Jul 31, 2015 10:23 AM
VANST3R
Lights
Jul 27, 2015 08:20 PM
laksjd84
Jul 24, 2015 05:12 PM
CrazyLogic219
Jul 23, 2015 10:58 AM
