In the middle of changing Compression Rod need help!!
Old Jun 26, 2008 | 11:17 AM
nemises's Avatar
In the middle of changing Compression Rod need help!! PICS
Is there a trick to getting the compression rods off. I am in the middle of changing them. I have all for bolts off (the 2 for the compression rod, and the 2 on the metal brace.) However, I cant get it off. The side near the wheel is free but the other side that bolts under the car will not come free. I have tried prying it off and gave it a few taps but i cant pop it free. Is their something else holding this thing on? Please advise.
Last edited by nemises; Jun 27, 2008 at 08:40 PM. Reason: Oh Boy from bad to worse update
Old Jun 26, 2008 | 08:33 PM
nemises's Avatar
Angry
Well things just got worse. Still cant get the compression rod free. I jacked up both sides of he car still cant get off. I tried to bang the heck out of it and it still wont come off. I tried getting the tie rod out the way so i could maybe twist the stuck side of the compression rod off. And know that bolt snapped so currently my car is non driveable. Initially the bolt on the compression rod was stripped so i grinded it off now a bolt will never thread onto that anymore. So my compression rod is currently not connected to the front hub. And my tie rod is just hagnging their also. I have know idea what im going to do.
Old Jun 27, 2008 | 12:02 PM
gnasrawi's Avatar
Take a butane torch, heat it up until red hot, and give it one big bang and should pop out with no problem.
Old Jun 27, 2008 | 12:59 PM
nemises's Avatar
Thanks I will give that a shot tonight. I dont want to bring it to the dealership cause A.) I will have to tow it. And B) they quoted me 625.00 to install the compression rods I bought and Install 1 new outer tie rod end.
Old May 5, 2010 | 12:38 AM
AARONHL's Avatar
Originally Posted by gnasrawi
take a butane torch, heat it up until red hot, and give it one big bang and should pop out with no problem.
will be doing this next week thank you
Old May 5, 2010 | 12:54 AM
thescreensavers's Avatar
Mr.202?
doesn't heat expand metal?
frankywashere
Aug 7, 2020 12:14 PM
kinetek
Aug 3, 2015 04:25 PM
keithk831
Steering & Suspension
Aug 2, 2015 09:50 PM
itschuckster
Jul 25, 2015 08:07 AM
LoSt180
Jul 15, 2015 08:31 AM
