alignment after Tein Basics
From: Toh-rensa,Ahteesia,Ahcadia,Montree Pak, Longa Beacha
Let me know if these numbers sound good.
I got my alignment done today, spent my morning at the shop. It wasn't bad, I just read a car magazine. Before the car was pulling slightly to the left, but that's a resolved issue now. Car is lowered 1.4375" in front, and 1.325" in rear (this is based on knowing the stock wheelarch heights.)
I had the shop install the SPC camber arms and toe bolts to help with the rear. Front suspension arms are stock. I only plan on going to the track once a year, so for 99% of the time, this is a daily driver on the freeways.
I had them raise the front slightly. I have a GT spec 4 point brace on the bottom of the car, and I was scraping over everything.
Camber
Left Front -1.8
Right Front -1.8
Left Rear -1.5
Right Rear -1.5
Toe in Total
Front 0.06"
Rear 0.06"
Here's why it took longer:
Weight with me in the car (about 170 lbs):
Left Front 1021 lbs
Right Front 950 lbs
Left Rear 902 lbs
Right Rear 833 lbs
Left weight 51.9%
Right weight 48.1%
Front weight 53.2%
Rear weight 46.8%
Cross weight 50%
The car does feel more planted like others have mentioned after corner balancing. I'll have to give it more time to see if I notice any other difference.
Camber
Left Front -1.8
Right Front -1.8
Left Rear -1.5
Right Rear -1.5
Toe in Total
Front 0.06"
Rear 0.06"
Left Front 1021 lbs
Right Front 950 lbs
Left Rear 902 lbs
Right Rear 833 lbs
Left weight 51.9%
Right weight 48.1%
Front weight 53.2%
Rear weight 46.8%
Cross weight 50%
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
Learned Hand
Oct 1, 2015 09:02 AM
joel extreme
SOCAL Meetings & Events
Sep 29, 2015 04:44 AM
