350Z H-Tech, Rear Right-Side Slightly Higher
Old Jul 3, 2008 | 01:20 PM
jlin615's Avatar
I just installed 350Z H-Tech like 2 days ago. The rear right-side (gas filler side) seem not have lower as much as the left side, probably less than 0.25in. higher. Any thoughts?
Old Jul 3, 2008 | 01:30 PM
Beebo's Avatar
have a fat ***** sit in the car on the left side hahaha
Old Jul 3, 2008 | 01:44 PM
redlude97's Avatar
trim .25" off the passenger side springmount to even it up
Old Jul 3, 2008 | 01:53 PM
jlin615's Avatar
Visually it looks even to the eye all around. Just when u try to measure it, you see the difference.
Old Jul 3, 2008 | 02:05 PM
redlude97's Avatar
its your decision if it needs to be fixed or not, mine's been like that since I got it in stock form, but noone's ever commented on it because its less than a 1/4"
Old Jul 3, 2008 | 02:33 PM
jlin615's Avatar
Yea, because it's less than 1/4" not really worth the effort to redo the springs. But I'm just curious why, maybe because I got only a quarter tank of gas?
Old Jul 3, 2008 | 02:34 PM
redlude97's Avatar
the weight distribution from left to right is not exactly 50/50, which leads to slightly uneven stance
Old Jul 3, 2008 | 08:41 PM
jlin615's Avatar
Okay, just filled up a full tank. This time I'm measuring with a measuring tape. The right side is 27.5in from the ground, the left side is 27in. I'm not going further with this, I'm just gonna go with what redlude97 said about weight distribution. From my research, many others experience this too.
Old Jul 11, 2008 | 02:14 PM
LightsOut's Avatar
SIETESG
i noticed the same for my htechs also. but it just the angle and the way the wieght is distributed to each side.
some days it looks lower than normal
Old Jul 11, 2008 | 02:29 PM
jlin615's Avatar
In the rear, is there like 0.5in difference left to right? I measured mine from the ground to center of fender.
Old Jul 11, 2008 | 02:49 PM
LightsOut's Avatar
SIETESG
but then agian u just recently installed the springs, they take about two months to really settle. i have had my springs for about 5 months now, and i think the drop looks good with my stock 19's
Old Jul 11, 2008 | 04:28 PM
jlin615's Avatar
So how's the drop on rear left and right for yours?
Old Jul 11, 2008 | 04:38 PM
tragedycat's Avatar
I've had my 350z H-Techs on for about 2 months now, my driver side rear has a bit over a 1 finger gap, my passenger side rear has a 2 finger gap. I hardly ever have a passenger in my car though and I weight about 200lb so I chalk it up to that.
The front may be slightly uneven as well but it's hardly noticeable so I've never really checked.
Old Jul 11, 2008 | 04:44 PM
LightsOut's Avatar
SIETESG
it depends some days my drop feels like the left side is higher, about pinky finger size higher.
then some days it looks about even.
in the end drop looks good, now that the springs have fully settled. i have about to finger gap ( with the lines on our knuckles going N and S)
Old Jul 11, 2008 | 04:48 PM
(>")> G35's Avatar
Get an alignment done? Lower side probably has more camber than the other...
