NRG bolt?
Old Jul 5, 2008 | 10:11 PM
Gfast's Avatar
NRG bolt?
hey, everyone
i just receive my NRG strut bar, but they didn't come with any instruction or any bolt. it only have the bar and two bracket to mount on top of the suspension.
is that how it suppose to be?
If it is not come with any instruction, than can any of u let me know what bolt i need. I can go to home depot and get those bolt, and i can use some tutorial on how to install this bar too.
i would appreciate for ur help.
i already use the search engine, but i didn't find much info on this.
thanks in advance
Old Jul 6, 2008 | 12:50 PM
k67p67's Avatar
My NRG STB came with M10 1.5 75mm bolts. You'll need 2 bolts, 4 flat washers, and 2 lock washers.
Old Jul 6, 2008 | 02:43 PM
Gfast's Avatar
thanks a lot
how about the bracket bolt that go on top of the suspension?
i saw three whole on each bracket i assume i will need 6 of those
thanks again
Old Jul 6, 2008 | 02:49 PM
rookie's Avatar
You should be able to reuse the stock ones.
Old Jul 6, 2008 | 04:27 PM
Boston's Avatar
Originally Posted by Gfast
thanks a lot
thanks again
The three 10mm strut nuts will be used to install the bar mounts.
Old Jul 6, 2008 | 04:34 PM
k67p67's Avatar
The top strut bolts are M8 1.25, not 10mm.
Old Jul 7, 2008 | 12:16 PM
Boston's Avatar
Thanks for the correction. For some reason I was thinking 10.
Old Jul 7, 2008 | 03:01 PM
Gfast's Avatar
thanks a lot
any tutorial will be great too
Old Jul 7, 2008 | 03:09 PM
k67p67's Avatar
WYSIWYG
It's self-explanatory. The brackets will only go on one way.
Old Jul 7, 2008 | 09:55 PM
Gfast's Avatar
coolz
thanks
Old Jul 10, 2008 | 02:20 AM
spooze's Avatar
im having trouble with mine. i installed it but i have to push my hood down a bit. its hitting the strut bar. its on the lowest setting i believe. i will play with it some more tommorow.
Old Oct 2, 2008 | 04:16 PM
Larry@Showtime's Avatar
Former Sponsor
Same problem with mine. I just got it today and it wont fit.
do these fit 07 coupes? still waiting for a call back from Toni at Riverside Infiniti.
Old Oct 3, 2008 | 11:07 AM
Former Sponsor
well my shop said it rubs hood, so i tried myself and there still seems to be a clearance issue. I mean,i can close hood but it doesnt look right. Also, the 2 outer bolts for the adjustments were bent. I need the ARC one.. this is a joke.
Old Oct 3, 2008 | 01:25 PM
bigc's Avatar
Wings Nation
You need to widen the slots on the brackets to provide some more clearance. Just use a file and a little bit of elbow grease - takes about 3 minutes.
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Picture Share
Feb 4, 2018 12:41 PM
Ninjay16
Engine - Intake/Fuel
Jan 14, 2016 01:44 AM
6spdGspot
Oct 5, 2015 01:55 PM
