Has any1 blown their stock shocks w/ TEIN springs?
Old Jul 11, 2008 | 12:09 AM
DrrSeuss's Avatar
I was thinking of putting TEIN H-Techs on my 03 coupe. The suspension on this car has never been altered. Normally on my cars, I put on a full coilover system but I only want to keep this car for another year but I still want to lower it a little bit. So...I don't have much experience with just aftermarket springs with stock shocks.
Has anyone blown their shocks with these springs?
Old Jul 11, 2008 | 12:21 AM
tragedycat's Avatar
I'm on 350z H-Techs, it's hardly even a drop. Your shocks will be fine, but you will probably be disappointed you paid $150 and install for basically nothing.
Old Jul 11, 2008 | 12:32 AM
jjyellow's Avatar
I did on mines after about 20000 miles,
Old Jul 15, 2008 | 02:35 PM
Infinite1's Avatar
20 Year Member
I have the 350z H techs running on my stock shocks. I installed them at 40k and it's 50k now and no issues. I've read on here that to possibly change them around 60k but we'll see. The drop is pretty moderate and i have a 5 min drive from home to work so i'll prolly get more life out of them.
Old Jul 15, 2008 | 03:00 PM
gary c's Avatar
Not likely....!
With the Tein H-Techs the drop is so minimal you won't have issues with the
OEM shocks. I only installed mine to reduce the gap over the top of the tires....and it worked....
Old Jul 15, 2008 | 03:07 PM
Beebo's Avatar
if your keeping the car for a year you should be fine
Old Jul 17, 2008 | 06:56 PM
deanfootlong's Avatar
i installed 350z h techs and also did the rear spring mount mod after seeing the results of 350z h techs on a g35. my shocks are just about dead now. but i have about 64k miles
Old Jul 18, 2008 | 09:40 AM
Infinite1's Avatar
20 Year Member
How bad was the ride when your shocks blew out? Was it really noticeable?
Old Jul 18, 2008 | 09:46 AM
Hi-TechG35's Avatar
^You ride will be horrible. Blown shocks on these cars are just horrid. You feel every bump, dip and pebble in the road. If you are worried just do it right the 1st time and get either a set of good coilovers or buy a set of aftermarket shocks to go with your springs.
Old Jul 18, 2008 | 10:42 AM
Infinite1's Avatar
20 Year Member
Well doing it right the first time all depends on the person...I've outlived my slammed integra days in the 90's Which is why i chose the Htechs. yeah i've looked into coilovers. I think with the coilovers i'll be tempted to go much lower. And I don't want that. Later on I plan to get some Dspecs but for now with only 50k on the shocks(10k on the springs) But I figure why not use the hell out of the OEM as I wont' be able to sell them.
Anyhow thanks for the tip!
Old Jul 18, 2008 | 11:02 AM
Gunmetal35's Avatar
I'm still on stock shock my springs are tanabe df210 installed at 19k I'm at 33K right now, still going strong no change but I'm gonna upgrade to coilovers pretty soon...
Old Jul 18, 2008 | 01:28 PM
Jeff92se's Avatar
Red Card Crew
Since the height isn't changed that might, you should be okay. But how long the shocks will last might be a function of the new springrates. If they aren't too much stiffer than OEM, you might be fine.
Old Jul 18, 2008 | 01:34 PM
iamericgee's Avatar
my shocks are bad and i have s techs my car has about 64k on it so im getting ready to change my shocks real soon
Old Jul 18, 2008 | 02:09 PM
silver g's Avatar
I had Eibach springs and after time my shocks got really bad. I'm sure the Eibach's greatly reduced the life of them. Not sure what kind of effect the Tein's will have.
I just installed Tein Flex Coilovers and it is seriously the best mod I have done yet. The difference between coilovers and lowering springs is a night and day difference. Wish I would have done it from the getgo. So much fun to drive now!!!
KruZZe
Feb 27, 2023 05:04 PM
g.spot
May 9, 2016 10:54 PM
Rose M
Oct 12, 2015 10:00 AM
Rose M
Sep 30, 2015 05:31 AM
