Brakes vibrate and make noise
Old Jul 12, 2008 | 02:50 AM
Andrei's Avatar
If I brake when I'm going 60mph or so the streering wheel vibrates hard. Also when I hit the brakes to stop completely the brakes make this cluncking sound right when the car is about to stop and it doesn't stop like it should, almost as if the brake calipers skip off the rotors. I also feel that in the brake pedal.
I already took off the wheels and the brakes have plenty of pad left and the rotors are not warped and they are smooth to the touch. Anybody know what's going on?
Old Aug 9, 2008 | 01:01 PM
anonymous_coupe's Avatar
same **** is happening to me. im getting pissed off
the car got to the point where it just squeaks non-stop even if im cruising at 35mph without even touching the brake pedal.
Old Aug 10, 2008 | 01:53 AM
godmans's Avatar
usual cause of such vibration:
1) unbalanced wheel and tire
2) warped rotor
3) shot wheel bearing
it is most likely the first two, but I would suggest you bring it to a mech to check it out since you mentioned that it doesn't stop like it should. G/L
rezendvous420
May 31, 2020 01:26 PM
Cskeet
Drivetrain
Dec 3, 2015 09:18 PM
MyfistYourFace
Aug 8, 2015 11:58 AM
Jussaku
Jul 29, 2015 11:45 AM
tehmoonrulz
Jul 19, 2015 10:44 PM
