Tokico Dspec Spring/Shock combo
Old Jul 23, 2008 | 01:31 PM
valetkyle's Avatar
Has anyone run with this setup? It claims to have the spring rates matched perfectly with the shock but appear to be soft rates. 1.2" drop. Any opinions? Tried a search, but couldn't find much.
Old Jul 24, 2008 | 03:00 PM
valetkyle's Avatar
bump
Old Jul 24, 2008 | 06:37 PM
superchargedg's Avatar
I am also looking at this setup but i hear it is new so i quess there isnt much info about it.
Old Jul 24, 2008 | 06:56 PM
EL-EE-ES's Avatar
its a rare setup. i run d-spec shocks with swift spring. many people on here run d-spec with tein, eibach, tanabe springs. i love my setup, its a little heavier then stock
Old Jul 25, 2008 | 09:24 AM
idrive_MD's Avatar
i just went with the usual Dspec- Z H-tech combo, not installed yet though.
i wish I would have gone with the RS-R or Cobb springs though instead.
I would think that for a typical driver it would still be an improvement over stock, but for roughly the same cost or less you could get the shocks/springs seperate and have better spring rates
Old Jul 25, 2008 | 12:15 PM
jigahus's Avatar
Dpsec with 350Z htech. Ridin dirty.
Old Jul 25, 2008 | 02:30 PM
valetkyle's Avatar
Am I understanding this correctly? The H-tech is only a small drop or since we would be using the 350Z springs its a better drop due to weight?
Old Jul 25, 2008 | 04:58 PM
EL-EE-ES's Avatar
a spring for the 350z on a g35 would give the g about 1/2 in. more of a drop
Old Jul 25, 2008 | 05:05 PM
idrive_MD's Avatar
On paper the H-tech drop isnt that big, but if you use 350Z Tein H-tech springs add .5 inches to the total drop. IIRC its .3fr/.2rr so it comes out as .8fr/.7rr
Heres a link to some good pictures of the effective drop:
https://g35driver.com/forums/brakes-suspension/221420-g35-coupe-before-after-tein-350z-h-tech-drop-pics.html
If you use G35 H-tech springs the drop will be as listed and they actually have softer spring rates, not worth it IMO.
I've gone back and fourth on using mine with thinking about going lower than what the Teins will provide, but I think the drop will be ideal for me because I only plan to daily the car. I will only go a different route if I was to sell them before I install the complete setup.
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
DRG35R
Sep 16, 2015 05:33 AM
spanky99l
Sep 7, 2015 12:46 AM
TheBay
Sep 3, 2015 03:27 PM
