can't remove rear brake caliper bracket
Old Aug 2, 2008 | 02:25 PM
bcgreen's Avatar
On my '04 coupe I cannot for the life of me remove the 2 bolts holding the caliper bracket on. Has anybody had this same difficulty and how did you over come this?
Thanks
Old Aug 2, 2008 | 04:44 PM
Meatshackle's Avatar
Deep Sea Moderator
Get a breaker bar or a piece of pipe to give you more leverage.
Old Aug 2, 2008 | 08:04 PM
Shakuya88's Avatar
Got an air compressor? Get an impact wrench and they should come off like butter
I don't think that would hurt anything.
Old Aug 2, 2008 | 09:13 PM
bigugly78cj5's Avatar
try some penetrating oil like PB blaster......... with a breaker bar/pipe like meat suggested.............
Old Aug 3, 2008 | 01:26 AM
Deep Sea Moderator
Also put down your wine cooler first.
Old Aug 3, 2008 | 01:40 PM
bcgreen's Avatar
I wish I had one for this particular job, so I guess I just look for an independent who is willing to remove the bolts and turn the rotary, since that is the only one giving me problems.
Old Aug 3, 2008 | 01:42 PM
bcgreen's Avatar
If I had a lift I could get enough length on the bar, as it is the end my bar is just a few inches from the floor.
Old Aug 3, 2008 | 04:53 PM
jjyellow's Avatar
put a wrench on it and hit it with a hammer
Old Aug 3, 2008 | 08:13 PM
bcgreen's Avatar
Did that before the breaker bar, the only other thing that used to work, in other vehicles I've worked on, was a propane torch, to heat up the bolts.
Old Aug 6, 2008 | 10:41 AM
Nine-GFC's Avatar
I had the same problem and this is exactly what I did. Bolts came off no problem.
MikeTanabe
Brakes
Aug 26, 2015 03:02 PM
kinetek
Aug 3, 2015 04:25 PM
hrdwirk1
Jul 14, 2015 05:46 PM
