best price for best drop
theres actually someone selling them new for $1000 shipped
https://g35driver.com/forums/suspens...coilovers.html
I personally think its worth $170 more for the damper adjustability, especially if you do alot of street driving.
u can get slightly used basics for $500 if that interests u btw
humm i duno...
im on sport suspen
so i think its pretty stiff....
pretty bummpy
i just want that slam look
preformance i can really care less......
i duno i would get springs
but i dont think i get the SLAM look i want...
So i duno
i need opinions....cuz ima get my wheels...together with my springs/coils
i need some help
im on sport suspen
pretty bummpy
So i duno
i need some help
Originally Posted by lniivedl
but if you think the oem sport suspension is too stiff, you are not gonna like the basics.
OEM springrates are
Front:314 Rear:427
Tein basics are
504 front and rear
SO I'd get the BC's.
btw you will need good camber kits front/rear if you wanna slam your car
OEM springrates are
Front:314 Rear:427
Tein basics are
504 front and rear
if you want slammed and your on sports suspension then just get some tein S-techs for the Z, it will lower you a lot and I think they're softer than your sports suspension...but you will still need a $$$ camber correction setup front and rear or you will eat up your tires very quickly like someone else said.
i normally wouldnt recommend that, but you stated the OEM is stiffer than you prefer and you didnt care about performance so there ya go.
if you go cheap on the camber setup with say a megan setup front and rear plus the tanabe springs you will probably come out right around $800, hell if you really want to go with all megan-racing parts because they make springs too.
Tein basics will only be height adjustable. And to me, they arent even THAT adjustable. BC coils will be height adjustable, and dampening adjustable with dampening adjustable extensions in the rear. If you wish with the BC coils, you can put the front of the car on the ground....if you wanna go that low. I am running the 12/10 spring rate setup and the ride is great and not even that stiff imo.
