endlink options ( I found these endlinks)
Old Aug 14, 2008 | 04:52 AM
GeeCoupe's Avatar
I have the clunking / rattling sound in the back by the suspension. I am lowered and I have the stillen sways. It seems that powergrid is just about the best possible choice but they are on the pricey side, more than i'd like to spend on endlinks. Its down to the revised factory or these http://cgi.ebay.com/ebaymotors/G35-c...5091QQtcZphoto
They are adjustable also, fairly cheap, i'm not familiar with the brand but considering them because I know an adjustable endlink can take the preload off of the sway bar. Are a heim-joint setup bad for endlinks?
Which one should I go with? Give these a try or revised oem? ( I don't think I am going to shell out for powergrids anymore. )
Old Aug 14, 2008 | 10:42 PM
GF-4D-G35's Avatar
The joints are the type that are supposed to wear out over time. SPL uses the same type and they have a good reputation. I went with revised OEM, not sure that I really got revised. The fronts are okay although I did have a problem with one of them and replaced it with the old one, thankfully that was the side that was not making noise. The rears just recently started making enough noise to warrant replacement. I have new OEMs for the rear that I will be putting on this weekend.
I agree that it is hard to pay as much for sway bars again for the end links. If you try these please post your impressions. The price seems much more reasonable.
Old Aug 14, 2008 | 10:44 PM
elayman's Avatar
it seems like my suspension squeaks every now and then from going over bumps, but i just greased my bushings and when i was under there the endlinks aren't broken or anything.. do they ever make squeaky noises?
ttrank's Avatar
Grocery getter
I have been looking into new end links too. Anyone else have info?
Old Aug 14, 2008 | 10:50 PM
ttrank's Avatar
Grocery getter
I'm going to try those.
I still need front ones.
Old Aug 15, 2008 | 12:31 AM
GF-4D-G35's Avatar
end links clunk - it is very noticeable and if you have never heard it before it will scare the crap out of you, it sounds terrible. You can't tell they are broken unless they snap, the joint is what breaks down.
compression roads squeak / groan
Old Aug 15, 2008 | 12:34 AM
GF-4D-G35's Avatar
I went with OEM front and rears because I am cheap. Riverside carries them and should be able to ensure you get the revised versions.
Aftermarket options are SPL and PowerGrid. I can't remember where you can buy them but there is at least 1 site sponsor that carries each brand. These go for about $300 for all four, or $160 for the front. I can't believe how much these things cost for the G.
Old Aug 15, 2008 | 12:46 AM
GF-4D-G35's Avatar
Sorry for all the posts but I thought I would get these links out here. These are the PowerGrid links. I researched this a while ago and it seems like people really like these.
Front:http://cgi.ebay.com/ebaymotors/03-07...4506.m20.l1116
Rear:http://cgi.ebay.com/ebaymotors/03-07...4506.m20.l1116
Old Aug 15, 2008 | 03:52 AM
GeeCoupe's Avatar
More like a metall clunk noise, ilm guessing I can get a couple of years if I go with the revised? But I know if I change to these cheap adjustables I'd be able to take off the preload from the swaybar and that could help them last also...
Old Aug 15, 2008 | 08:40 AM
GF-4D-G35's Avatar
It is hard to say how long they would last. I have read elsewhere that once you get the preload off of the sway bars they perform much better.
Old Aug 15, 2008 | 04:34 PM
GeeCoupe's Avatar
Then I may gai for the aftermarket in that case, but I already know if I get new OEMs I can buy some time on them
Old Aug 15, 2008 | 04:54 PM
GF-4D-G35's Avatar
Maybe try revised OEM first. That way if it is not the end links making the noise you have not invested a ton of money in fixing a non-existent problem and have the money to fix the real problem.
Old Aug 15, 2008 | 05:29 PM
05GRide's Avatar
I have the Powergride endlinks and I LOVE them. They are on the pricey side but I'm a fan of doing things right the first time. They are fantastic. The car is a LOT more neutral by taking the preload off the sway bar. Noticeable difference and you can crank the sways down to stiff/stiff and not ever have to worry about an OEM endlink snapping either.
I'm very happy with my purchase.
Old Aug 17, 2008 | 01:45 AM
DaveB's Avatar
Millionare dollar question though: Do they make any noise what so ever?
Old Aug 17, 2008 | 12:44 PM
GF-4D-G35's Avatar
I would not think so. The only time the stock ones make noise is after the joint breaks down. With these you can adjust the length to take the preload off of the suspension thereby reducing the chance of the joint disintegrating.
The suspension will also perform better since it is not already flexed to a degree. I think that if you are really slammed you will notice the difference in the ride, otherwise you may not.
Someone who has them should chime in but from what I have been reading once these are in (PowerGrid or SPL) the noise stops. The noise also stops if you put in new OEM links but I am not sure how long that will be good for. I have put several thousand miles on my OEM front end links without the joint breaking down but mine is not set all that stiff nor am I really slammed.
