How do I adjust the emergency brake tighter ?
Old Aug 17, 2008 | 02:03 PM
68_GT's Avatar
need help on this....just failed inspection because mt e-brake doesn't grab hard enough
I changed the front and rear pads not long ago. Must have missed something there.
Old Aug 17, 2008 | 06:46 PM
xnyc's Avatar
there should be a 10mm nut under the ebrake
Old Aug 17, 2008 | 08:05 PM
LMG_35C's Avatar
See the service manual adjustment below
Old Aug 18, 2008 | 11:54 AM
Jeff92se's Avatar
Red Card Crew
Here's a pic of the rotor off (from my 06Z brake upgrade) so you can see what the adjuster actually look like.
Old Aug 18, 2008 | 06:36 PM
68_GT's Avatar
OK so there is no way my installing new rear pads messed with that adjustment right ? How would that get out of adjustment ?
thanks guys I didn't realized the e-brake was a seperate brake shoe system.
LMG_35C can you e-mail that service pic to me please ?
smithc@mcdcsc.org
Old Aug 18, 2008 | 06:42 PM
Jeff92se's Avatar
Red Card Crew
There's nothing preventing you from installing new pads with the e-brake the way it is. But since you're in there, I'd adjust them. I read about too many e-brake roll back accidents with the manual guys. And letting the car roll back on the auto tranny is hard on the tranny. Just take off the rubber cover on the brake rotor, line it up to the adjuster and adjust it per the manual. I ignored the cable part of the instructions and went directly to the shoe adjustment part.
For the attachment, just click the pic and print it out.
Old Nov 16, 2008 | 08:09 AM
Texasscout's Avatar
What a PITA, most Euro cars just have a 10mm nut below the Hand Brake lever.
Old Feb 10, 2009 | 12:19 AM
ThirstyTurtle's Avatar
ya that's how my RSX was. Just pop out the center console and tighten two bolts...DONE.
Old Feb 10, 2009 | 11:41 AM
Jeff92se's Avatar
Red Card Crew
Well yes and no. What you are doing is adjusting the cable. The procedure I illustrate adjusts the shoes themselves.
It's not difficult at all once you get the hang of it. That's why I posted a huge picture
Old Feb 11, 2009 | 09:09 AM
idrive_MD's Avatar
yeah I did mine recently to get rid of the e-brake boner I had going on which was inpart to me going in the reverse direction the first time, once I fixed it, it only comes up a few inches now...nice and tight
Old Jul 26, 2010 | 03:48 PM
mayhemj30's Avatar
I was having issues with the PB not grabbing so I adjusted the brakes using both the adjusting in the drum and by tightening the cable. I thought I had fixed the problem because before the pedal went all the way to the floor, but now it only goes half way before the tension stops it. The PB holds the car great when pointed downhill, but will roll like the PB isn't even on when pointed uphill. It's an AT so I don't have much worry, but I do hate putting all the pressure on the tranny. Is the rolling back with the PB on a common problem with these cars?
Old Jul 26, 2010 | 05:40 PM
saywat?'s Avatar
do i have to replace the self locking nut per the instructions? and what is the specified value for the lever stroke?
jilljann1
Jul 21, 2020 08:12 AM
sales@czp
Suspension-Vendor
26
Nov 6, 2017 03:04 PM
DRG35R
Sep 16, 2015 05:33 AM
G35-2004-mt6
Sep 11, 2015 04:16 PM
