2005 G35 AT 55k miles brake vibration
Old Aug 18, 2008 | 12:23 AM
lemmy999's Avatar
My brakes have caused vibration for a while but it is getting really bad. I guess I need new front rotors but I definitely don't want the stock rotors cause I don't want them vibrating again. Can someone recommend some good rotors that aren't too expensive, but won't be vibrating again in 20-30k miles? Should I also replace the pads when I get new rotors? Right now there is plenty of material left on the pads I have.
Old Aug 18, 2008 | 12:58 AM
miltoda's Avatar
why don't you just resurface the rotor? The 05-06 non X sedan and all coupes from those years had much more oversized brakes, so rotor wear shouldn't be something you would have to worry about unless that's 55k miles of heavy city driving and heavy braking.
Old Aug 18, 2008 | 02:53 AM
GooberGman's Avatar
I've got all 4 straight 05' rotors removed at 22K for a BBK that you can have cheap if you want more OEM's. PM me if interested.
Old Aug 18, 2008 | 02:03 PM
JadeRaven's Avatar
I have the same problem with my '05 AT.
You should be able to just resurface the rotors at least once. Also, when resurfacing or changing the rotors you should swap out your pads.
I have heard of some getting away with keeping their pads, but it will increase the liklihood of re-warping or messing up the rotors again.
Old Aug 18, 2008 | 02:26 PM
gary c's Avatar
Disc vibration....gets old!
Before you go out and drop a wad of cash on new discs have your OEM units
trued, then any time you have your wheels removed/installed make sure they
use a torq wrench set at 80# for install. Impact guns are the cause (one of them) of
disc warping due to inconsistent over tightening.
Gary
Old Aug 19, 2008 | 10:10 AM
lemmy999's Avatar
Ok, thanks I will have them resurfaced and replace the pads. I am happy with the performance of the OEM pads, but is there another type I should check out? I thought about the EBC Green pads. I have used those on my motorcycle and they wear very very fast though. Are they the same on the G?
Old Aug 19, 2008 | 06:13 PM
mesias's Avatar
Before resurfacing your rotors read this article and give it a try. I did and it worked for me. I'm very incline over the mythical part of "warped" disks.
http://www.stoptech.com/tech_info/wp...rakedisk.shtml
Old Aug 21, 2008 | 11:36 AM
lemmy999's Avatar
Yeah, I never believed the "Warped rotor" thing either because my father has always said it was build up (like that article says). However I bought the car at 40k miles and I don't drive it that aggressively. But one time I was just slowing from about 110mph to 60mph and it vibrated really bad. Ever since then it has gotten a little worse. If I am going 80 and moderately apply the brakes I get vibration, I can let off and reapply and it stops. I guess I will try some new brake pads and scrub the rotors with garnet paper and bed them in to see if that helps. I once had this problem on a mustang and I had the rotors turned and sanded the pads and the problem went away never to return.
Old Aug 21, 2008 | 11:39 AM
lemmy999's Avatar
Anyone ever used Axxis Ultimate Brake pads? Are they any good? They claim pre-conditioning eliminates need for bed-in, but I dont' see how that is possible. I am also considering the Hawk Ceramic pads.
laksjd84
Feb 28, 2026 01:58 PM
Blakelyg35
Aug 15, 2015 12:12 PM
lemmy999
Jul 25, 2015 12:13 PM
AustinErkl
Drivetrain
Jul 18, 2015 05:44 PM
Scredeur4
Steering & Suspension
Jul 17, 2015 06:30 AM
