Looking for softer ride
Old Oct 3, 2008 | 05:24 PM
  #31
jlin615's Avatar
Originally Posted by stan schatz
nO I THOUGHT I PURCHASED THE STANDARD G35 SEDAN, IT HAS THE 17 INCH TIRES AND WHEELS. DOESN'T THAT SPECIFY NON SPORT MODEL?
THANKS IN ADVANCE FOR YOUR HELP.
STAN
You've got the anniversary limited platnium edition
Old Oct 5, 2008 | 11:54 AM
  #32
Q45tech's Avatar
Remember tires act as springs and have a sidewall stiffness [depending on PSI] of 10 times stiffer than coil springs. Two springs in series are lower than the lowest in rate, so tires reduce wheel rate stiffness to the road by ~ 10%.
A different tire with a larger sidewall ratio can emmulate a 10-15% softer spring.
By 40k I would think the shocks are weak compared to brand new [especially in rebound/expansion stiffness].
Old Oct 5, 2008 | 12:32 PM
  #33
mikeb2004's Avatar
G35Halo, do you have 17" wheels? If not, try stepping down to 17" wheels and tires. I have a set of 17s and the stock 18s for my coupe, and the ride is much smoother with the 17s, though I prefer the ride on the 18s, but that's just me. You'd save $ when you need tires. If you already have 17's, also consider the type of tire you have. A stiff sidewall will of course make the ride harsher and a touring tire would give a better ride. Some tire places will let you test drive a set of tires and take them back (for an exchange) if you don't like them. Just a couple ideas.
Old Oct 5, 2008 | 03:27 PM
  #34
gugarci's Avatar
I agree.
Going to 17's should help it you are using anything bigger. Also the speed rating of the tire will affect the ride quality. Try V-rated or even H rated tires if you are using a tire rated higher than V. They V and H rated tires have a softer sidewall. The stiffer sidewall on a high speed rated tires also adds to the harshness of the ride.
Old Oct 5, 2008 | 08:45 PM
  #35
athens's Avatar
Originally Posted by jigahus
Get some tokico dspec shocks and play around with the dampening settings. I have 3 from firm on all my shocks and it is riding way smoother than stock.
Is it possible? More ride compliance than OEM or KYB Excels for non-sport models from the D-Specs?
Old Oct 5, 2008 | 09:02 PM
  #36
athens's Avatar
Originally Posted by G35Halo
That's right, I'm willing to give up some of my stability for a smoother ride. It has been fun the past (almost) 6 years but I find everyday driving on L.A. streets to be too harsh for the current set up.
BTW, if anyone saw the report, LA was ranked as having the worst roads in the country.
My 03.5 G35 sedan has the "sport" package. What are my best options to accomplish a more plush ride with regards to price and effectiveness?
Thanks.
I'm with you. Chicago received over 100,000 new potholes on it's roads after a couple of horrendous blizzard followed by Siberian freeze storms.
I have the standard suspension on my 2003 coupe. 17" wheels. When OEM Goodyear Eagle RS-As wore at inside of rear tires by 35K miles I switched to Goodyear Eagle ResponsEdges and ride improved somewhat.
You could try an H-rated (to 140 mph constant) Touring tire like the Goodyear Triple-Tred which I see fitted on many a BMW 5-er or MB E-class as OEM replacements. Or a Bridgestone Turanza Serenity.
Yet I am wondering if a change to KYB Excels will SIGNIFICANTLY improve ride compliance over my OEMs at 56K miles.
What do you say Q45 tech?
Old Oct 5, 2008 | 09:24 PM
  #37
athens's Avatar
q45
Old Oct 21, 2008 | 04:54 PM
  #38
stan schatz's Avatar
Thanks to all who sent me their sugestions. I guess we just made a snap decision that was wrong. We have deceided to bite the bullet and sell the car, it's a shame as it only has 13k, anyone interested in buying it let me know. Thanks again
Stan S.
Old Nov 8, 2008 | 11:02 PM
  #39
jlin615's Avatar
i believe just shock/spring essential.
http://www.trademotion.com/partlocat...11&catalogid=2
KruZZe
Feb 27, 2023 05:04 PM
sales@czp
Suspension-Vendor
26
Nov 6, 2017 03:04 PM
prinny
Nov 22, 2015 11:07 PM
Fox843
Nov 7, 2015 05:43 PM
gprabhu
19 Inch
Oct 2, 2015 05:55 PM
