View Poll Results: Which Spring Set do you recommend for me?
G35 H-Techs
25.93%
350Z H-Techs
11
40.74%
S-Techs
37.04%
Multiple Choice Poll. Voters: 27. You may not vote on this poll
Flat Out - What drop can I do w/ no mod other than Springs?
Old Sep 9, 2008 | 02:07 PM
  #46
redlude97's Avatar
Originally Posted by Nickk6
You freaking kidding me, this is one of those arguments I can win with proof. I own an alignment machine (http://www.hunter.com/pub/product/al...ems/index.htm), I can throw my car on the rack and print my cars specs and they are all within tolerance.
I would like to see this, you are dropped on 350z h-techs?
Old Sep 10, 2008 | 06:19 PM
  #47
DaveB's Avatar
I don't believe it because it's impossible. There is no way your car is dropped on 350Z H-techs and still within camber spec on either end. There is nothing to fiddle with up front other than toe. So, with a 1" drop (you're car has more), you naturally increase negative camber of which it is not adjustable. When my car was on the OEM springs, there was barely percievable front negative camber. With the Z springs, there is noticable negative camber and if I remember correctly from the alignment print out, it's nearly 1 degree. Out back there's even more. Regardless, I was able to align my car to coupe specs (barely with the camber), but there's no way it could get back to sedan specs. You should recheck your print out and make sure the called out car isn't a coupe.
Old Sep 11, 2008 | 11:15 AM
  #48
Nickk6's Avatar
I'd do a printout, but unfortunately right after posting my comments I sold my springs to a coupe and installed Sedan Tein Stechs.
But just to confirm, it was Sedan spec, I did the alignment myself so I know it wasn't coupe spec.
Old Sep 11, 2008 | 11:26 AM
  #49
Nickk6's Avatar
350z H-techs on a sedan with spacers is not the way to go either. Look why I did the swap in a rush. One bushing was like this, the other was dangling in the middle of the spring. If you drive aggressive spring bushings are a bad idea.
Old Sep 11, 2008 | 04:24 PM
  #50
Q45tech's Avatar
Within the wide oem spec is near worthless as true NOMINAL is what one wants...............the design point not the in spec range for the masses.
Old Sep 12, 2008 | 12:08 AM
  #51
yeaitzwill's Avatar
sorry guys this might be really off topic but i found some eibach lowering springs for a realllllyyyy cheap price. The thing is it came off of the old body G35 COUPE and I have a 2008 G35 SEDAN. Does anyone know if it will work on my car?
Old Sep 12, 2008 | 12:24 PM
  #52
WhiteonWheat's Avatar
Ok. THANKS for all the great info.
I'll keep things OEM and live with the wheel gap. I don't have room for added stress about brand new tires getting worn out quickly - no thx.
Thanks Guys!
-WoW
Old Oct 14, 2008 | 11:12 AM
  #53
tragedycat's Avatar
I have 350Z H-Tech's and had to buy SPC front and rear camber kits, and I'm still a bit negative but within OEM spec. All the camber **** cost me like 5x more than the actual damn springs.
Kelvin Style006
May 23, 2016 03:47 AM
DRG35R
Jan 31, 2016 07:14 AM
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
Rose M
Oct 12, 2015 10:00 AM
