Solid VDC, ABS, and SLIP light on
Old Sep 27, 2008 | 02:40 AM
theGster's Avatar
i changed my brake pads and put on 20mm spacers today. after 1hr my ABS, VDC, and SLIP light came on and it was solid. i checked if my VDC was disabled and it was. i didn't check my ABS, but i am sure it is not working also. what went wrong?
Old Sep 27, 2008 | 03:22 AM
FlyingLumpia's Avatar
check your brake fluid.
Old Sep 27, 2008 | 03:47 AM
joedaddy1's Avatar
+1.. maybe u got a leak?
Old Sep 27, 2008 | 06:32 AM
theGster's Avatar
that simple? what about the sensors?
Old Sep 27, 2008 | 10:09 AM
when mine was low they were on, when I filled it up they when away. I searched it on here and it seem others had that problem too.
Old Sep 27, 2008 | 10:22 AM
Noremac's Avatar
A low brake fluid level in the master cylinder will cause the symptoms you describe. It's the first obvious thing to check, and if it's the problem, the all the lights should go out after a few minutes of driving.
Mry
Mar 3, 2023 01:03 AM
SiMpLyMoDiFiEd
The FX-Spot
Dec 2, 2021 04:35 PM
JermaineSanders
Aug 18, 2015 08:57 PM
Wayne9011
Aug 17, 2015 01:24 AM
Wayne9011
Jul 27, 2015 11:25 AM
