Brake, VDC, and Slip light on
Old Oct 20, 2008 | 08:51 AM
SigEpG35's Avatar
hey everyone,
yesterday coming back from the skins game my vdc, slip, and brake light stayed on the entire drive and the brake light would sometimes go off. samed deal when i woke up this morning.
anyone have any idea about this? my tranny has been sticking quite a bit lately but i would assume thats unrelated and i know my brakes are desperately in need of a change. sounds like full stoptech stage 2
thanks,
cory
Old Oct 20, 2008 | 10:12 AM
thatguy II's Avatar
low brake fluid
Old Oct 20, 2008 | 10:56 AM
pinkii's Avatar
all those lights came on for me last Feb on 295... I was going 80+, then I wasnt..... my battery died in mid drive. But I would check the brake fluid oh yeah and get some new brakes.... lol
Old Oct 20, 2008 | 03:23 PM
SigEpG35's Avatar
brake fluid all looks good - 2 resevoirs whatsup with that?
about to order stage 2 stoptech with slotted rotors
lights havent come on since this morning so i have no idea at this point
Old Oct 20, 2008 | 03:26 PM
trey's wife's Avatar
My horns hold up my halo
It is either 1) brake fluid, 2) brake pads or 3) the ABS sensor.
Old Oct 20, 2008 | 03:27 PM
SigEpG35's Avatar
so low brake pads will trip these sensors?
Old Oct 20, 2008 | 03:33 PM
Yes, that is one of the possible causes of those lights coming on. It's usually one of the first 2 that posted but my '04 had the third one and there have been some others post here with that being the cause as well. It's pretty easy to fix though
Old Oct 20, 2008 | 03:35 PM
SigEpG35's Avatar
well hopefully thats good news. we shall see when i get the stoptech stage 2 thrown on.
any problems with drilled/slotted with cracking and such?? is it worth it to throw down the extra 100 bucks
Old Oct 20, 2008 | 03:38 PM
I'm not familiar enough with the aftermarket brakes to give you a good opinion there, hun. Post up in the Tech section and I'm sure you can get some good input there. Several of those folks really know the in's and out's.
Old Oct 20, 2008 | 03:41 PM
badassflip's Avatar
check your brake pads, rotors, and brake fluid.
Old Oct 20, 2008 | 03:45 PM
norcal2006g35's Avatar
what the heck does VDC even stand for and whats it change when you turn it off? is that bettter for racing??
Old Oct 20, 2008 | 03:46 PM
Canadian's Avatar
Canada, eh?
Are you sure it isn't the brake fluid? Even a VERY minute difference will create the light. Make sure the level is at max. Not any distance below the line, as I've experienced two cars with it just a bit below the line and the lights came on. When I filled it back up, it went away. And there is only 1 reservoir, not sure where you're looking.
Old Oct 20, 2008 | 03:47 PM
Canadian's Avatar
Canada, eh?
VDC stands for Vehicle Dynamic Control. It controls the rear wheels when it senses they have lost traction. When you loose traction, it will cut power to the rear wheels so you can regain control of the car.
http://en.wikipedia.org/wiki/Electro...bility_control (same thing as VDC).
Old Oct 20, 2008 | 03:52 PM
SigEpG35's Avatar
ill check the fluid again later, any opinion on slotted versus drilled/slotted
Old Oct 20, 2008 | 04:04 PM
Canadian's Avatar
Canada, eh?
There really is no answer to which is better. They both provide great cooling and different weight benefits, but I do know from many experienced track users that drilled rotors will crack over time with track use. I've seen them on a few cars personally. But, if you don't track your car a lot or at all, then I would get drilled because I think they look better.
