Steering Wheel Vibration
Old Nov 21, 2008 | 10:27 AM
PG8901's Avatar
I have a 2005 G35 Coupe.
Lately, I've been able to feel more bumps on the road, and the steering wheel seems to vibrate and/or shudder more.
Also, when I drive on the highway, at higher speeds, I feels even more bumps on the road.
And, when I am on the highway, and I am driving along the curve of the road, there is definite vibration and shudder from the steering wheel.
Do I simply need my wheels balanced, or could it be more complicated than that?
Old Dec 10, 2008 | 03:35 PM
shaf140's Avatar
vibrating wheel at higher speed is usually due to an alignment issue. Just get it checked and tires balanced.
Old Dec 10, 2008 | 03:49 PM
SkylineGTR2789's Avatar
i have the same year..usually mine vibrates when i stop hard from high speeds (havent dont that too many times) but it still vibrates..the whole console vibrates.
Old Dec 11, 2008 | 03:54 PM
JamesDarc's Avatar
The same thing has happened to me. But for me its been at a normal speed (25-40mph). When i slow down the wheel will shake and so will the shifter. it has happened like 3x but i haven't really found a real cause for it... it could be the alignment.
Old Dec 12, 2008 | 11:45 AM
Q45tech's Avatar
"vibrating wheel at higher speed is usually due to an alignment issue."
Vibration is NEVER caused by alignment issues unless the alignment parameters have destroyed the tires, wheels, rotors, bearings, or tie rod ends.
Now slop in steering can be pinion wear/tension or grossly mis adjusted off center toe.
Old Dec 21, 2008 | 02:24 AM
TheG35Dude's Avatar
Vibration when braking hard or at high speed is caused by warped brake rotors, you need to replace them.
If the vibration gets worse as the speed goes up your wheels are unbalanced. Before you take it in try cleaning the wheels off, it doesn't take much mud stuck to the inside of the wheel rim to cause a vibration. this kind of vibration is most often felt threw the steering wheel.
Bad alignment will cause the car to pull to one side and in general the car will not track straight on the highway. Unless you lowered the car or screwed around with the suspension system a bad suspension system won't cause a vibration.
Tire cupping is also a problem on the G35 coups with staggered tires because you cannot rotate them. This will also cause a vibration as speed increases.
Old Dec 21, 2008 | 11:01 AM
Q45tech's Avatar
"Tire cupping is also a problem on the G35 coups"
Tires on G35 don't usually cup, they do however suffer from heel toe feathering.
Old Dec 21, 2008 | 11:18 PM
TheG35Dude's Avatar
True, tire cupping is rare on the G because the rear tires are often burned off long before tire cupping can occur.
jsimonk
Dec 22, 2023 03:49 PM
Mkhlmnn
V36 Interior, Exterior & Lighting
Feb 16, 2016 09:27 PM
derres
Aug 28, 2015 03:27 PM
Karnicle
Jul 23, 2015 05:08 AM
