TEIN CS coilover rear shock clunk noise ?
Old Nov 22, 2008 | 10:51 PM
GTreeFive's Avatar
Really happy with the coilovers except for the rear Shocks.
Sounds like the strut is loose and knocking around in back on the upper two bolts. really noticable when cruising slow around the neighborhood, small bumps, small waves in the pavement.
When i get annoyed/pissed, hammer the car into a turn or accelerate hard I dont get a noise. Seems to be quiet under load.
Had a shop check out the top of the shock pillow mount assembly and its fine, they reinstalled the shocks still noisey.
Anyone else have this issue?
The guy I bought them from gave me the Tokico D's to use in the rear bc they are quiet and the mount looks beefy. So I might swap to those in just the rear.
Old Nov 23, 2008 | 11:44 PM
Knight's Avatar
One of my old links. I had this annoying problem when I first installed the Tein CS. After it went back to Tein for repair, problem solved. It's a Tein defect.
I totally understand how annoying this is....Good luck!
https://g35driver.com/forums/brakes-...tles-gone.html
Old Nov 25, 2008 | 01:55 PM
G35Papa's Avatar
I have the same issue...same exact issue and I've never been able to pin point it outside of if being the actual shocks themselves.
I just emailed Tein USA to see if they can finally get this resolved for me.
Thanks for the info Knight.
Old Nov 25, 2008 | 09:27 PM
Skaterbasist's Avatar
Retired SuperMod
I get a clunk on my rear right whenever im cruising and the car goes over a bumpy surface. It's a pronounced clunk. And I have brand new HKS Hipermax III Sport coilovers.
I don't think its a coilover issue. I'm going to recheck and make sure all the bolts are torqued down properly. Maybe I missed a bolt
Old Mar 6, 2009 | 03:12 AM
gspothawaii's Avatar
ever get a fix for this?
rezendvous420
May 31, 2020 01:26 PM
reavensf
Sep 17, 2015 11:30 PM
atk08
Jul 30, 2015 03:12 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
cyrus32
Jul 18, 2015 06:22 PM
