brake fluid level after new pads?
Old Nov 27, 2008 | 07:18 AM
EL-EE-ES's Avatar
I recently changed out my brake pads. The brake fluid level was at the max line before I changes them, now it's above the line. Is this normal? Is it because with new thicker pads the pistions are pushed in more or is there air in the system? The brakes work fine
Old Nov 27, 2008 | 08:47 AM
Boston's Avatar
Did you ever add fluid in between pad changes?
Old Nov 27, 2008 | 09:06 AM
EL-EE-ES's Avatar
no i havent...
Old Nov 27, 2008 | 12:03 PM
superchargedg's Avatar
It is normal as you compress the pistons in the caliper to install new pads the fluid has to go somewere.
Old Nov 27, 2008 | 03:18 PM
kenchan's Avatar
yeh, that's why some folks tell you to remove the reservoire lid
before changing pads to relieve the pressure that gets built up
inside the bottle.
im going to be changing my pads next summer and expecting to
suction out some fluid during/after the change cause it's at
the max line right now and my pads are about 50% done.
Old Nov 27, 2008 | 03:44 PM
gary c's Avatar
New Pads....?
This is perfectly normal, it's caused by compessing the calipers. Don't remove
any it should return to the full line within a few miles and stops!
Gary
Old Nov 27, 2008 | 03:51 PM
EL-EE-ES's Avatar
thanks guys! That's what I thinking, just didn't want to have air in the system. I'll bleed the brakes this coming up summer
Old Nov 27, 2008 | 04:13 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
...you changed pads;
Have you changed the fluid recently?
Rather than just bleeding it's good to flush it with new.
Danielek
May 1, 2022 01:28 PM
boostelevator
Brakes
Oct 5, 2015 08:56 AM
bryanr
Drivetrain
Sep 30, 2015 06:31 AM
3000vr4tt
Sep 7, 2015 12:48 AM
