G or Z s tech
Old Dec 18, 2008 | 12:53 AM
repin_LB's Avatar
G or Z s tech
So still trying to search before i put these in so debating between the G and Z s-tech. so i have the G stech's in hand and now i read up that the drop depends on the sport suspension also now... I have the non-sport suspension which came with the 18" rims and i guess the 19" are considered the sport. So the g s tech will give a drop around 1.0/.9 correct? and the Z stech will give 1.2/1.1?
this is what https://g35driver.com/forums/brakes-...w-updates.html states
So if i want around a 1.1-1.2 drop which should i consider getting? im guessing the z s-tech's now
Old Dec 18, 2008 | 11:57 AM
Beebo's Avatar
Sport and non sport are the same height... any z springs will lower the G 1/2in more than any G springs
also the G s-techs are softer spring rate than the Z s-techs
Go with the Z s-techs
Old Dec 18, 2008 | 02:35 PM
SwanyJr's Avatar
Okay, thank you for clearing that up for me as well. I just read about it a few days ago and I wasn't sure there was a drop difference, but I knew about the softness of the G S-Techs. Will they install the same as the G version?
Old Dec 18, 2008 | 08:37 PM
repin_LB's Avatar
aite thanks beebo. yea i think im leaning toward the z stech's now but the total drop will range about 1.1 or 1.5+? i heard some pplz drops are around 1.5 or so
Old Dec 21, 2008 | 08:21 PM
Beebo's Avatar
Yes
Im not sure. sorry
KruZZe
Feb 27, 2023 05:04 PM
prinny
Nov 22, 2015 11:07 PM
AJC128
Nov 1, 2015 11:55 AM
bigmike
Sep 17, 2015 01:58 PM
